text to a circle pattern?
Pathfinder450
Post by Pathfinder450 »
How do I make text to wrap around a circle pattern?
Thanks in advance for any help you can give to me.
Pathfinder450
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: text to a circle pattern?
Post by LeviFiction »
Select the text you want to add to the circle. Ctrl + Click on the circle to select them both. Right-click on them and select "Fit text to path."
Or you can select "Fit text to path" from the "Objects" menu.
Now that will always put the text on the top of the circle. If you want the text on the bottom of the circle then you need to convert the circle to a patch object.
Right-click on the circle only, make sure nothing else is selected, and select "Convert to path." The circle should now be a path object, right click on the circle again and in the Edit submenu you'll see "Reverse Path" select that and now when you fit the text to the path it will be on the bottom of the circle.
Here's a tutorial on it: http://www.michelespaintshop.com/psp-text-on-curve.php
Pathfinder450
Thank you so much LeviFiction. I will try to do this.
Thomas
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Post by teknisyan »
Also a tutorial that I created way back.. http://abielonline.blogspot.com/2009/07 ... th-or.html
I used PSP X2 here but you can still apply the steps on PSP X3.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
bhnl
Post by bhnl »
I am following the instructions above, to put text on the bottom of a circle. Convert to path is OK, but in Edit sub menu, the reverse path command is visible, but greyed out (like all other commands). What could be wrong?
I use PSPP X3 by the way.
bhnl
Post by bhnl »
bhnl wrote:I am following the instructions above, to put text on the bottom of a circle. Convert to path is OK, but in Edit sub menu, the reverse path command is visible, but greyed out (like all other commands). What could be wrong?
Already found it... needed to use the pen tool to see the right options.
