X4 1920x1080/50p
Oti
motherboard: ASUS P6X58D-E X58 S-1366 ATX
processor: INTEL CORE I7 950 3.06GHZ 8MB S-1366
ram: 6 GB
Video Card: GIGABYTE GEFORCE GTX 460 OC 1GB PCI-E DVI HDMI
sound_card: On motherboard
Hard_Drive_Capacity: 1.5 TB
X4 1920x1080/50p
Post by Oti »
Been reading the posts here on the forum regarding 1920x1080/50p (60p) and I understand it's "out of standard" ** (so far), but is there any workaround to create a template for 1920x1080/50p (60p) for X4, or just do we have to wait for the software developers to catch up after the standard has been updated?
Using the Sony HDR-CX700 at 1920x1080/50p so would be neat to be able to create files/discs with optimized quality... :lol:
** http://www.avchd-info.org
"July 1st 2011
AVCHD Format Co-Promoters started licensing the AVCHD Format
Version 2.0
The AVCHD Format has been updated to Version 2.0 by adding new specifications
for 3D and 1080/60p,50p. New trademarks; "AVCHD 3D", "AVCHD Progressive" and
"AVCHD 3D/Progressive" are introduced."
Kingston
motherboard: Gateway [Acer] DX4860
processor: Intel Core i5 3rd gen. 3 GHz
ram: 8 GB
Video Card: Intel HD 2500
sound_card: Bluetooth
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Re: X4 1920x1080/50p
Post by Kingston »
You won't be able to create a template, but you can share to a 1920x1080/50p if you have a clip with those specifications. You cannot use smart render. See this: http://forum.corel.com/EN/viewtopic.php ... 30#p222781
Oti
ram: 6 GB
Post by Oti »
In X4 can't change to 50 frames/sec or MPEG-2 as described in http://forum.corel.com/EN/viewtopic.php ... 30#p222781
I'm I missing something, or is this only for X2?
Screendump from my X4:
Any suggestions?
//Stefan
That's for Standard-def video. You need to choose the Custom option located at the very bottom of the menu. Then in the Create video file dialog window change the Save as type from MPEG files, to MPEG Transport Stream files (*.m2t). Next press the Options button, go to the Compression tab. You have the options of AVCHD and AVCREC. Using AVCHD the video format will be h.264 (and greyed out), uncheck AVCHD and then you can change the format to MPEG-2.
Back to the General tab, and you can change the frame rate from the SD frame rate of 29.97 or 25fps to 59.94fps (NTSC) which would be the 60fps for NTSC, or 50fps for PAL.
Oti
ram: 6 GB
Post by Oti »
I can't find such menu. See attached screendumps. Where is the "Custom option at the very bottom of the menu"?
//Stefan
My instructions were for rendering your project, the Share step, not setting the project properties. As Kingston stated, you can not do that.
Oti
ram: 6 GB
Post by Oti »
Ok, but I'm not able to share the project at 1920x1080/50p either. There is no MPEG-2 or "Custom option located at the very bottom of the menu" as far as I can tell in X4, or I'm I missing something completely? I can only see NTSC-DVD and PAL-DVD, no MPEG or MPEG-2 in the drop-down menu.
In Settings -> Make Movie Templete I can do what you write, but not able to use it anywhere as far as I can tell.
Could you please attach a few screendumps to show?
"That's for Standard-def video. You need to choose the Custom option located at the very bottom of the menu. Then in the Create video file dialog window change the Save as type from MPEG files, to MPEG Transport Stream files (*.m2t). Next press the Options button, go to the Compression tab. You have the options of AVCHD and AVCREC. Using AVCHD the video format will be h.264 (and greyed out), uncheck AVCHD and then you can change the format to MPEG-2.
Back to the General tab, and you can change the frame rate from the SD frame rate of 29.97 or 25fps to 59.94fps (NTSC) which would be the 60fps for NTSC, or 50fps for PAL."
//Stefan
How's this, my screenshot is animated.. ;)
Oti
ram: 6 GB
Post by Oti »
Thanks a lot! Now I got it!
One more thing though. When chosing to burn to Blu-ray discs from VSX4 (source still 1920x1080/50p [mts-files]) the result is 24p. Any way of creating Blu-rays with full-hd/50p from VSX4?
I asume VSX4 will have an update for this in the future as AVCHD standard version 2.0 (released in July 2011) now supports Full-hd with 50p/60p. I hope Blu-ray will support 1920x1080/50p in the future too... Would be great to be able to burn Blu-rays at 50p.
Thanks again.
//Stefan
Post by Trevor Andrew »
Hi Ken
Nice one, is this a silent movie, :) or is there an issue with my PC’s audio. :(
I noticed on other YT videos that they were silent. :?: :?:
Hi Stefan
Try using Make Movie Templates Manager –Add to create a template of your original video files.
The Add function works for some types but not all, if successful, do not edit the template, simply close.
The template will be available adjacent to the Custom option.
Its worth a try, not sure if it will work though???????
No Trevor ... I think a few of us have tried the Make Movie Template > Add route more than once for 50/60p video, and it simply does not produce anything except a default DVD template. As the OP mentioned, the AVCHD standard was only recently altered to include 50/60p (plus 3D), and VS is simply not built to accept anything along those lines apart from 1280 x 720p or AVI using mpeg transport stream as the base.
Oh, and while I thank you for the kind attribution for the "silent" movie above, in fact it was Ron who made it... And it was also a select movie for me... :lol:
Oti
ram: 6 GB
Post by Oti »
Should I use upper field first, lower field first or frame based?
Trevor,
It was silent, when I read Oti's post requesting screenshots, I decided I could do the whole thing faster this way.
Oti,
When you're using interlaced video always use the same field order as your source. So if your camcorder records using Upper Field First, use that. Most camcorders that record to MPEG, will always use Upper Field First. Most all MPEG video is Upper Field First. Now taking this one step further and not to confuse you, but I think is important to mention. DV, (which uses the *.avi wrapper) almost always is Lower Field First. Here's where it could be confusing. If someone had a DV video file, made a video DVD from it, this would produce an MPEG-2 video file that would use Lower Field First. Always check the field order for the video clips you insert into your project. Never mix field orders, ie; Upper with Lower Field, one of them is going to be reversed.
Frame Based, is non-interlaced, and can be mixed with either, it will take on the field order of the interlaced video in the project.
To whom it may concern……..
Apologies to Ron and Ken for once again getting the pair of you mixed up.
I must admit it does happen a lot but I usually notice before hitting the Submit button.
