change language in VSProX4
oldcop49
motherboard: Micro-Star
processor: Intel Core 2 quad2.33GHz
ram: 4GB
Video Card: NVIDIA GForce 9600 Gt
sound_card: High Definition onboard
Hard_Drive_Capacity: 1800GB
Monitor/Display Make & Model: Medion
Post by oldcop49 »
Hello,
I'm using VSProX4 in English,while my native language is Dutch . I wonder if it's possible to change the language to Dutch(NL) and if it is,how to do that. Thank you
Re: change language in VSProX4
I guess where you live in "Old Earth" you would be speaking Flemish... But to get to Dutch, I think you would have to reinstall and indicate The Netherlands as being where you live for the TV system question (even if you in fact live in Belgium...)
oldcop49
ram: 4GB
Post by oldcop49 »
Dear Ken,
You guess right,I'm speaking Flemish because I'm living in the dutch speaking part of Belgium. I will try what you suggest but it seems so unlikely for me one have only to fill in the Netherlands at the moment of the installation to change the language of an English version ? But I will try. Thanks anyway.
Did you buy it from an English-language source?
oldcop49
ram: 4GB
Post by oldcop49 »
Yes,I did.
Post by Trevor Andrew »
There is an update patch for X4
I noticed the documentation had a section titled Nederlands with a separate download link, (probably the same file anyway)
I don’t know if this will help, but may be worth trying the VideoStudio Pro X4 Service Pack 1
Assuming you haven’t already installed.
tridy
motherboard: Asus P5K-V
processor: Core 2 Extreme Q6850
Video Card: GeForce 8600 GTS
sound_card: Creative SB X-Fi Music
Hard_Drive_Capacity: 700GB
Monitor/Display Make & Model: LG L246WH
Post by tridy »
I had a similar problem with the language. I wanted to use English but it was Russian after the installation (probably the setup found that it is in my regional settings or something).
So, what you need to do is to open the file u32comm.ini from the Corel VideoStudio Pro X4 in the text editor, and find a place where it says
Code: Select all
[vstudio.exe]
ShortCut=1
Name=Corel VideoStudio Pro
Version=14.0
AppIni=GG_App.ini
DefaultKeyBase=1
EnableLanguageFolderRedirect=1
EnableLocaleHook=0
UseMSAlLayer=1
ShowDetailMsg=0
;LocaleID=0404
;DebugLevel=3
now you need to replace
Code: Select all
 ;LocaleID=0404
with
Code: Select all
LocaleID=0413
(note that there is no semi-column in the beginning)
for the other language codes, you can look in the same file under [LCID] section.
Now you need to save this file (you might need first to save it on the desktop or other location because of the admin rights and then copy it to the X4 folder)
oldcop49
ram: 4GB
Post by oldcop49 »
Thank you for the offered solution. I tried but the program remains in English.Ik wonder how come no one can set the desired language in a multilingual program. Thanks anyway.
tridy
Post by tridy »
I was pretty sure it worked, so I made an experiment changing the settings on my system, I managed to get Dutch GUI, and here are the screenshots,
English on the left side, Dutch on the right side. Click on the image to get a big image
again, make sure you remove the ";" from the line with the LocaleID. And when you save the file, you need administration rights to save/replace u32comm.ini file. You might want to start the notepad with admin rights first. Well, you get the point, I guess.
Let me know if it works.
oldcop49
ram: 4GB
Post by oldcop49 »
Yes, Success! Good work from you. I can not thank enough. The first attempt wasn't successful because of the ";"
I owe you a pint. Thank you very much.
Kindest regards
lucwille
motherboard: Dell Inc. 0J503P A02
processor: 2.13 gigahertz Intel Core2 Duo
ram: 4GB
Video Card: ATI Mobility Radeon HD 4650
sound_card: IDT High Definition Audio CODEC
Hard_Drive_Capacity: 500+500 GB
Monitor/Display Make & Model: Algemeen PnP-beeldscherm [Monitor] (17,1"vis)
Post by lucwille »
Hi, I just had the same problem but to change the language from English to 'Dutch Belgium'. So I changed in u32comm.ini the code to 0813. But it didn't work. Then I tried 0413 wich is the code for 'Duch Netherlands' and that was succesfull. Work to do for Corel....
