Clarify option
lionel
motherboard: Hewlett-Packard 30D9 83.1E
processor: Pentium Dual CPU T2330 1.6 GHz
ram: 2GB
Video Card: Onboard laptop
sound_card: onboard laptop
Hard_Drive_Capacity: 120GB
Monitor/Display Make & Model: Mobile Intel(R) 965 Express Chipset Family Generic
Clarify option
Post by lionel »
I switched from PSP 8 to Photo Pro X3 a year or so back and have found the switch great except for two small issues.
1. X3 is a lot slower in carrying out a lot of tasks. Guess when I upgrade my computer soon this will be less of an issue.
2. I often use the Adjust - Brightness & Contrast - Clarify option, especially if a photograph is suffering from just a little bit of glare. Very effective very often. Clarify seems to have disappeared somewhere between version 8 and X3 and I have not managed to duplicate the effect in X3. Any suggestions? (apart from please put it back in the next version Corel)
Till I sort this one out I won't remove PSP 8, I keep using it too often for just this one function.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Clarify option
Post by LeviFiction »
Technically Clarify is now "Local Tone Mapping" but they do function slightly differently. Most of the time you won't notice a difference but if you apply it enough times it will be different.
However, the Clarify command in scripting still functions like the old clarify method. Again it won't be a problem if you don't over apply the effect but if you do and you don't like how "Local Tone Mapping" does it then you will need to switch to using the Scripting option.
lionel
ram: 2GB
Re: Clarify option
Post by lionel »
LeviFiction wrote:Technically Clarify is now "Local Tone Mapping" but they do function slightly differently. Most of the time you won't notice a difference but if you apply it enough times it will be different.
Thanks LeviFiction. Champion! Seems to magic away that slight glare pretty well. I never get too carried away with overdoing things on photographs. I reckon if someone who knows imaging processing can see what I have done then I have probably done too much. At this stage I have a mate in bird photography saying "Your lens is better than mine". I doubt it - I will have to show him a trick or two.
