My OS is ME with the Fat32 4gb limit. I want to try to figure out what total size .avi files I can capture and place in VS8's timeline in order to render an mpeg2 file no larger than my 4gb limit.
TIA,
Erock
Thanks GeorgeW. I guess my question wasn't clear.GeorgeW wrote:just use the combined length of your .avi files in the bitrate calculator. I'm not sure I understand what you are asking...
if you have a 45-minute .avi, and a 15-minute .avi, you use 60-minutes in the bitrate calculator (assuming one audio track and and one video angle).
Is that what you are asking?
BINGO! Thanks GeorgeW, that's exactly what I was looking for. I have all the variables (codec, etc.). I will try it tonight.GeorgeW wrote: You go by the MINUTES of the source video, and mutliply it by your bitrate (video + audio) to give you the resulting mpeg2 file size.
In the bitrate calculator at videohelp.com/calc.htm, you can hit the Advanced button. You can then work with custom sizes by entering a bitrate -- it will tell you the resulting size. or entering a custom size, and it will give you a bitrate. But the KEY piece of the puzzle is the duration of the video to be encoded (not the size of the video to be encoded).
GeorgeW (or anyone else), I'm still a bit (pun intended) confused regarding the bit rate calc. Below are the properties of my .avi file. What is confusing me is the audio bit rate.erock1 wrote:BINGO! Thanks GeorgeW, that's exactly what I was looking for. I have all the variables (codec, etc.). I will try it tonight.GeorgeW wrote: You go by the MINUTES of the source video, and mutliply it by your bitrate (video + audio) to give you the resulting mpeg2 file size.
Thanks GeorgeW. Since I'm in the US, MPEG audio is out. Let me see if I have a handle on this.GeorgeW wrote:for uncompressed audio (LPCM) use 1536kbps as the bitrate.
This takes up alot of space compared to Dolby Digital or mpeg audio.
NOTE: mpeg audio is ok for PAL, but it is not an NTSC Standard. So some NTSC DVD Players will not playback mpeg audio...
