I looked in PiP no luck
Flying picture in and out
phaseman
- motherboard: ASUSTeK Computer INC. P8H61-M LE Rev x.0x
- processor: 3.10 gigahertz Intel Core i5-2400
- ram: 32gb
- Video Card: ATI Radeon HD 7870
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: Triple LG 24'
My Brain in numb, I'm sure this is easy but mind is blank on this. I wish to fly a picture in sit for 2 second then fly out over my main track.
Re: Flying picture in and out
First question is it Comfortably numb
Ok... That's not as easy as it should be, if VS used real moving/motion paths. There is the Enter/Exit provision for objects used in overlay tracks. It depends on if you want your photo to fly in as a standard shape. If so then you can use it. It is found on the Attribute tab, under Direction/Style. Clicking one of the arrows under each, will cause the object to enter or exit based on the direction of the arrow.
Once you set the direction, you need to set the Pause/Duration for your photo. This is done by the blue bar beneath the preview window. Moving the orange handles to the right and left adjusts this. The longer the blue bar, the longer the image is static, and the faster the motion of entering and exiting. If your blue bar is short, then it will take longer for your image to enter and exit, and your image will be displayed for a shorter period.
With VS X3 and X4, you can use the PiP filter, from New Blue FX. It is very customizable, using keyframes. You can have your image fly-in, then have various effects appear, like blurred boarders, have your image titled one way or another, have a reflection and so on.
To use a PiP filter you need to:
- First make sure your image on the overlay track is full sized/Fit to Screen. The filter is designed to work best this way.
- Apply the Full Mask to your photo.
- Now apply the PiP filter to your image
- Click on the Customize button for your PiP effect
phaseman
- ram: 32gb
Ron you're a legend, just what I was looking for.
And yes its comfortable numb
phaseman
- ram: 32gb
Hey Ron
This why I needed the advice
http://youtu.be/A4rmSvJiVNc Just goto 5:23 and you will see why.
Thanks again
Thanks again
Looks good..
You're catching on. I'll add this to the Video Products Tutorial Forum.
Here's a link to it.. http://forum.corel.com/EN/viewtopic.php?f=27&t=42854
phaseman
- ram: 32gb
