But I noticed that when I opened the histogram palette that there was no graph display other than what looked like a single stright line (with no width) in the center of the photo. I tried several other RAW photos and they were pretty much the same - sometimes empty, sometimes very, very small curves, but so low on the graph that it was easy to not even see them. I then tried some of the converted jpgs from Dxo and Elements 8 and they seemed OK. Visible histograms with normal height. The other software I have displays the RAW histograms normally. The distribution is not pleasant because there is such a bright background, but the curves are easily visible and of normal height. I began to wonder if there was some issue with PSPP X3 processing RAW Canon cr2 images that might be causing this problem for me.
My PSPP X3 is up to date with all service packs, but I can find nothing of this issue in the knowledgebase. Is anyone else having this problem?
Thanks.
