Hello,
Trying to update ULEAD PHOTO EXPRESS 4.0, but the link on me sending a link SHIFT ULEAD PHOTO EXPRESS 6.
Could someone point me how to update my version please?
And the site of COREL there that UPDATES versions 2, 3 and 6, could not find version 4.
cordially
PS: I am French and I'm not good in English, I apologize in advance for my possible errors;)
Update Ulead Photo Express 4.0
Re: Update Ulead Photo Express 4.0
Welcome to the forums,
I see that there are no updates listed for version 4, which to me means that they did not release any patches for it.
Thank you for your welcome Ron P
That's what I thought also
Would you have any idea how I can get the updates about this release please?
Unless a member of the forum, with this update, this gives me the update.
How do you know there were any updates for it? What I suggested is that Ulead did not release updates for versions not listed. So for versions 4 and 5 there were no updates released.
Well because I have version 4.0 and it seems to me that there was a version 4.1, but I can be wrong?
I can't find any documentation of an update for that version. Even the old Ulead website only lists updates for PE 6. http://www.ulead.com/tech/pe/pe_ftp.htm
The old Ulead learning center does list any new tutorials for PE6, but does have tutorials for PE4.. http://www.ulead.com/learning/learning.htm
Are you having problems with the program, where you think it needs an update/patch? If not I wouldn't be concerned about it. The main reason is that if there was at one time an update for it, it is no longer available anywhere I can find.
Sorry for the delay in replying.
The link to the documentation of PE4 is the same as for PE6.
Well there is a problem of sudden interruption of the program in some cases, such as the treatment of a high resolution photo.
Nothing too embarrassing, but sometimes annoying.
I would do with, it's been many years I use this software, which I find very complete for basic retouching, and I learned to do with these little annoyances.
Having lost my original software, I just buy a German retailer, to tell you how much I am attached to this software to get him to Germany
As you seem to know the world COREL, I ask you a quick question, if I could, of course:
COREL software you would know the same style as PE4, with options: Select a color Select by SmartSelect and with good adjustment options please?
Anyway, I want to thank you for the interest you have shown to my problem, I sincerely appreciate
friendly
friendly
In Corel's current programs, they have a tool that is the same as the old Smart Select. In fact there are a couple of tools that behave the same as the Smart Select. Depending on what program is being used, the Selection Tool will vary.
PaintShop Pro Photo
First I'm not sure you can still purchase this one where your located. I know it is still available in the Corel U.S. Store
Corel current offers PaintShop Photo Express. I've never used this program, so I really can't offer any advice on it. I'm guessing by the name, that it is a watered-down version of PaintShop Pro. It should have the same Selection Tools or at least very similar, to the ones already mentioned. One thing I know you need to consider is what's affordable?
PaintShop Pro is currently discounted on the US site, $29.99
PhotoImpact can be purchased on the US site for $29.99
CorelDraw Graphics Suite $399.00
PaintShop Photo Express $39.99
Paintshop Photo Express is the only program of the above that I do not have, and have not used. So based on that. Keep that in mind when I make the following statement. If you are currently running WinXP, or Vista and don't plan to upgrade in the near future, then I would opt for PhotoImpact X3. It's affordable, not that difficult to learn to use, and most importantly, it does not have the bugs that PaintShop Pro has. The current version, PaintShop Pro X3 is wrought with bugs.
Hope that helps a little..
PaintShop Pro Photo
- Selection Tool, which uses various shapes, (square, rectangle, ellipse, circle, rounded-rectangle, rounded-square, triangle, pentagon, hexagon,star and arrows)
- Freehand Selection: This has the Edge Seeker, Freehand, Point-to-Point, Smart Edge. This is the tool that is very close if not exactly what you're used to in Photo Express. You draw around the edge of the object you want to select.
- Magic Wand: You click on a color in your image and it will make a selection based on the color.
- Standard Selection Tool: It uses shapes (Square, Rectangle, Circle and Ellipse) to create selections.
- Lasso Tool: You draw around an object you want to select. It also allows you to incorporate "Smart Lasso", which behaves the same as your Smart Select.
- Magic Wand Tool: Same as mentioned in PaintShop Pro Photo
- Bezier Curve Tool: You make you selections in a Linear fashion. The lines are connected by nodes that can be edited if need be
