How to override the 15 min limit while export to youtube ?
My account does not have 15 min limit so why the corel application forces me that limit
and
i cannot find other settings to make so good video "1280 * 720" 25 frames etc that are used when clicking youtube button.
Want semi-HD (not full-hd) but it would nice to be able to adjust the bit rate so that the size is under 2gb
youtube upload limit
Re: youtube upload limit
There's not any way to over-ride the old YouTube limit. You should create your video file first, then just go to your YouTube account and upload it from there. If you're not wanting full HD, what resolution are you wanting, 720p or 480p? The 720p refers to 1280 x 720, and the 480p is 720 x 480.
Share—Upload to Web-YouTube—Mpeg4 HD 16:9 will create a template to :-
MPEG-4 Files
24 bits, 1280 x 720, 25 fps
Frame-based
H.264 Main Profile Video: 5000 Kbps
44100 Hz, 16 Bit, Stereo
MPEG AAC Audio: 128 Kbps
Using Settings--Make Movie Templates Manager you will be able to create your own template to the same or similar settings and control the bit rate.
You can also try Avi-Mpeg4 compression which will allow you to create a similar template.
Many other options / compression types are available.
Once you create a template it will be available from Share Create Video File, to the bottom of the list.
MPEG-4 Files
Frame-based
jukka
- System_Drive: B
- processor: thunderbolt
- ram: 32bmw
- Video Card: s3 triodent
- Monitor/Display Make & Model: whaat?! 4 monitors. Yup! 4
- Corel programs: psp 2020, videostudio 2019
Thank you trevor! This is it - seems to work.
Altough had to skip to 3rd tab and change settings there before it let to change resolution in the first tab.
Yep that is a bit of an issue, I do not think there is a definite order to setting the template.jukka wrote:Thank you trevor! This is it - seems to work.
So you will have to jump between tabs to find the correct options.
Setting one tab alters what’s available in the other tabs.
