Problems with creating DVD
wkadams
operating_system: Windows 8.1
Post by wkadams »
I am using VS X2. I am trying to create a DVD of my project. I have assembled my files/projects, created a menu, and previewed. This is as far as I can get. The prompts at the bottom of the page are not displayed properly. I have a "back" prompt in the lower left and it looks like there is the start of a prompt in the lower right. I have adjusted my screen resolution to no avail. I would appreciate some help. Thanks
W K Adams
WK Adams
Re: Problems with creating DVD
Post by Trevor Andrew »
Some users running W7 did have problems displaying all buttons.
As far as I know there is a patch to fix this issue.
The image below shows how X2 burner module should display as.
click image for larger view
Do you see all buttons
Corel info
You may be best to manually update Direct X, there is a related post at the top of this forum
wkadams
Post by wkadams »
Treavor
Thanks for the information. To answer your first question, no I do not see all the buttons. I followed your infomration and applied the update which corrected the problem. Thanks for the help. Very much appreciated.
WK Adams
