In PSP P X2 and PSP X3 Ultimate
Lorraine
- motherboard: Dell INSPIRON 580
- processor: INSPIRON 580
- ram: 4GB
- Video Card: Intel Grapics
- sound_card: Integrated
- Hard_Drive_Capacity: 581 GB
- Monitor/Display Make & Model: Dell 23" monitor
OS Windows 7 IE8 580 Dimension
I was trying to fix a picture's background last
night and the Push tool didn't work.
Nor did the Smudge. I tried in both versions.
I tried to make a Stat, (Slide) I guess it would turn out to be,
the background didn't fill after making a tile seamless.
Do I need to update? I don't see any place to update in
PSP X3.
another question:
My tools are too small for me to see them, how can I make them
bigger. There was a box showing up beside some pictures in PSP X2,
that said it was zoomed to 500 kb..Now the puter has gone to
French and I donèt use written French.......
I will throw this PC out and try to get my XP fixed.
PSP X3.
another question:
df
- ram: 64gb
- Hard_Drive_Capacity: 1 Tb
Re: In PSP P X2 and PSP X3 Ultimate
About the Push and Smudge tools not working, make sure you're on the layer that you're trying to make adjustments too. Make sure you don't have a selection made, the Marque (the dotted outline around the edge of a selection) can be hidden if you click Selection> Hide Marque or Ctrl+Shift+M. It's not unheard of to hide the Marque with the keyboard accidentally.
As for the tool icons being too small click View> Customize> Options tab> and check Large Icons.
For the language click File> Preferences> Switch Languages and see if you can get it done that way.
Good luck.
Good luck.
Regards, Dan
Lorraine
- ram: 4GB
Thanks Dan, I will try to write this message again. I lost the previous one when I went to File, Prefs to fix the French writing... I can't even write French very well so never use it.
There it's fixed. Thanks it was very annoying.
I tried with the push and smudge in PSP X2 and X3 and neither will push or anything. It is a photo of my Great, Great 2 yr old, granddaughter. I asked my daughter the Grandmother, who uses a Mac, if it was Photo Shopped and she said; "No, it is her own hair." I said "Are you sure, it isn't something that has been worked on?" I got "No" for an answer. It looks like it is the same background, but I can't tell. I know the little one likes to play with brooms and mops as she cleans while playing.....sort of..
I don't want to post the picture publicly. Thanks for the help.
The photo hasn't any border on it.. seems plain enough, so I don't know.
They really must have moussed, fluffed and teased it to make it looks so nice...
About my icons in the Tools being hard for me to see, when I mouse over, text is small too.
Will it make the icons on my desktop Larger. That I don't need, very seldom use them.
Kathy_9
- Hard_Drive_Capacity: 2TB
Lorraine,
Your desktop icons will not be changed. By following Dan's instructions you will only change the icons within PSP.
Kathy
Kathy
Lorraine
- ram: 4GB
Thanks Kathy, will give it a try.
-Lorraine
-Lorraine
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Aside from following DF's suggestion you can also try and resetting your workspace by following these steps. You can do that by pressing and holding down the SHIFT key then double-click on the PSP icon then when you received the message "DO YOU WAN TO RESTORE PAINTSHOP Pro TO ITS DEFAULT STATE?" just click OK.
Another thing, PSP X2 Ultimate is not fully compatible with Windows 7, though there are users here (including me) that was able to install and use PSP X2 Ultimate.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
Lorraine
- ram: 4GB
Thanks Abiel; I think it works, I need lots of experience to use it and
PSP PX3. I think I liked PSP X the best.
It works, it seems but I'm not very good yet...
thanks
-Lorraine
thanks
-Lorraine
Lorraine
- ram: 4GB
Thanks Dan, your suggestions for the larger Icons worked.
I can't see them very well yet, but at least I can see them
a little better
thanks
-Lorraine
a little better
thanks
-Lorraine
LindaSue
- motherboard: Gigabyte
- processor: 2.71GHz AMD Athlon II X2 215 processor
- ram: 3 GB
- sound_card: Realtek AC97 Audio [onboard]
- Hard_Drive_Capacity: 1320 GB
- Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
- Corel programs: Paint Shop Pro X2, X4, X6
Lorraine, are you using the Graphite interface? If everything looks a very dark gray then you are. You might be able to see your icons more easily if you turn that off. To turn it off go to the View menu and uncheck "Use Graphite Workspace Theme"Lorraine wrote:Thanks Dan, your suggestions for the larger Icons worked.
a little better
thanks
-Lorraine
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
Lorraine
- ram: 4GB
LindaSue wrote:Lorraine, are you using the Graphite interface? If everything looks a very dark gray then you are. You might be able to see your icons more easily if you turn that off. To turn it off go to the View menu and uncheck "Use Graphite Workspace Theme"Lorraine wrote:Thanks Dan, your suggestions for the larger Icons worked.
a little better
thanks
-Lorraine
Linda Sue: (or anyone)
"Use Graphite interface was checked." I unchecked it and
tried what you suggested with the Graphite interface and the icons went grey.
So then I put it back with the checkmark. It's better than Gray. I'm using PSP PX3 ultimate which evidently need the checkmark.
thanks Linda sue.
*Another problem, for anyone that knows what I'm writing about:*
Deleted it as nobody answered. It's been long enough
