Because the inbuilt MPEG encoder lack descent contrast Im thinking of using another video/audio encoder.
I then have a question about the audio. If I separate the audio from the video in the project, is the 5.1 information preserved in the wav file?
Preserving 5.1 with split video and audio?
Radioman62
- motherboard: Gigabyte G31M-ES2C
- processor: 2.8Ghz DC running at 3.4GHz [on extra hormones]
- ram: 2Gb
- Video Card: Nvidia Geforce 9500GT [silent]
- sound_card: External M-Audio Audiophile
- Hard_Drive_Capacity: 1 Tb
- Monitor/Display Make & Model: LG wide Flat [generic PNP]
- Location: Stora Höga, 45 km north Gothenburg on the westcoast of Sweden
Regards // Ove Tegnér
Re: Preserving 5.1 with split video and audio?
If you are using the “Split Audio” function then I assume yes, but this file will be used only in VS timeline.
If you choose Create Sound File then under the Options button will allow you to choose 5.1 audio channel
This will create a wav file of the entire project, or project preview range.
I do not use 5.1 audio, other users may have better idea………….
Radioman62
- ram: 2Gb
Thanks Trevor
I have to try and see what comes out avfter muxing/encoding with another encoder.
