2 Questions about saturation & selection tool
yogirajj
processor: AMD Panthum II Core 6
Hard_Drive_Capacity: 1.2 Taraby
Monitor/Display Make & Model: Acer HDTV
Post by yogirajj »
Question #1.
Were can I change the "color saturation" to use for my "color changer"?
Question #2.
When using "point-to-point" or "edge seeker", is there a way to go back one or two steps, without having to start all over again?
wds937
motherboard: Dell 0HN7XN A01
processor: Intel Pentium Dual Core E5800 - 64-bit - 3.20 GHz
ram: 4 GB
Video Card: Intel G41 Express - integrated
sound_card: Realtek High Definition Audio - integrated
Hard_Drive_Capacity: 320 GB
Monitor/Display Make & Model: ASUS VS247
Re: 2 Questions about saturation & selection tool
Post by wds937 »
yogirajj wrote:Were can I change the "color saturation" to use for my "color changer"?
The Color Changer Tool does not have a saturation control. However, you can approximate this by creating a duplicate layer above your current layer, performing the color change in that duplicate layer, and then changing the new layer's opacity to a lower value. Maybe, start at 50%, and work up or down from there. Also, try experimenting with that layer's blend mode.
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Post by df »
For question number 2 I don't think there's a way to unclick clicks once they've been clicked. However what I do is just continue on with my clicking and then come back and subtract or add as needed.
Regards, Dan
yogirajj
Post by yogirajj »
Thank you so much guys for your quick response. This is interesting, because in the PDF instruction manual I got with my purchase (on page 83); it says: in the "materials properties box" I can set these values, however, I checked all over the place, and there was no specific module for the color changer "saturation". I like your suggestion, I'll try it as soon as I get a chance.
Hmm, that's what I thought. However, I discovered that creating another layer, and using the "object extractor tool" works 100% better than using the selection. Ususally, all I have to do is erase a small portion of the edges and that's it!!.
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
What they're saying in the Help file is to choose a replacement color with a low color saturation. You do this in the Materials palette where you set the Hue, Saturation and Lightness/Luminance. They''re saying that it's better to choose a color with a low saturation (around 100) rather than a fully saturated color (255).
On the Materials palette, click the Color button on the Style drop-list, and choose a solid color.
If the Materials palette is not displayed, choose View Palettes Materials.
For realistic-looking colors, set the Saturation value (in the Material Properties dialog box) closer to 100 than to 255 (full saturation).
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
yogirajj
Post by yogirajj »
Ok, so, it simply means choose lighter color shades??? Now, in terms of hue, saturation, etc., the only options i've noticed is in the "layer pane". The layer pane has a pull down menu of fixed options, which appear to be of various filters/sub plugins. It is located just under the opacity bar. Now this seams to be what I am looking for. I experimented with a few colors/menu options and it looks great!!
Thank you guys for having so much patience with me. It is really difficult adjusting to a new program, especially after using an old one for years.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
To answer your second question, as you may find a need for the selection tool again, just hit the Delete key and it will go backwards along the selection for you.
yogirajj
Post by yogirajj »
Awesome!!!! Thank you so much!!!
yogirajj
Post by yogirajj »
LindaSue wrote:What they're saying in the Help file is to choose a replacement color with a low color saturation. You do this in the Materials palette where you set the Hue, Saturation and Lightness/Luminance. They''re saying that it's better to choose a color with a low saturation (around 100) rather than a fully saturated color (255).
Ok, I didn't realize I could also accomplish this in the "Adjust" Menu/Hue and Saturation. Nothing was highlighted because I had nothing selected. I"m getting there. I got my PSP x3 book, hopefully, i'll be a master in no time!!
LindaSue
ram: 3 GB
Post by LindaSue »
I'm glad that you asked that selection question. I didn't know that you could do what Levi posted about pressing Delete and I'm sure that it will come in handy sometime.
wds937
ram: 4 GB
Post by wds937 »
Good luck! I have been using PSP for years, but I don't think I'm anything close to a master. :)
To me, this is like many other full-featured or complex software applications in that PSP does so many things and has so many variations on those things. I learn more as I need to do something new, as the way I am doing something doesn't quite fit the situation at hand, or as I just plain stumble onto something. That's the beauty of forums like this one--we can all learn from each other as we ask questions, answer questions, and read solutions that worked (or didn't) for others.
yogirajj
Post by yogirajj »
Yes, I soooo agree with you. To tell you the truth, the only reason I asked, was because I remembered the same feature in PhotoShop. So far, my only disappointment is that, I don't find as many compatible plugins for PSP, as with PS :roll: . Which is is a shame because I truly think that PSP rivals PS big time...
