VS7 SE DVD capture problems - bottom of window - please help
rowens
Post by rowens »
New to video editing and ULead VS and could use some help. Ran a search of this forum but could find an answer....
First, i converted all of our old SONY analog home videos over to MiniDV thru the A/V input on our JVC camcorder. Now when i try to capture them onto the PC, the bottom 3 or 4 lines are off center.
When i try to capture video that we recently recorded directly to the JVC camcorder, there are no 'wiggles' at the bottom of the screen.
Is there a way to correct this? Even if i could just overlay a letterbox onto the bottom of the video that would be perfectly acceptable. Or is there a setting or filter or something that i could get it to look ok?
Sorry for what is probably a pretty basic question to most... i'm a newb at this sort of stuff...
TIA....
Rick
THoff
Post by THoff »
That's normal, and will only be visible when viewing the video on your PC. What you are seeing is the overscan area, which is usually obscured on a TV. If you will be watching this video only on a computer, you can use UVS' cropping filter to trim off a few lines at the bottom, but this will add to the time it takes to produce your video / DVD.
rowens
Thanks!
Post by rowens »
Thanks THoff for the quick and helpful response....
So much to learn.
Regards...
