I generally have ½ a dozen graphics minimized in the full editor where they dock from the bottom left by default. When switching to the Organizer and back to Full Editor the minimized graphics have moved to a position relative to the top of the Organizer’s lower view panel. This generally leaves the minimized graphic’s behind the currently open graphic.
I see no way to lock the minimized graphics and the only work around is to manually dock them at the top of the Full Editor’s workspace, which is a time consuming hassle.
Any ideas out there?
Robert
Switching from Organizer to Full Edit
R7A
- motherboard: Asus K8N-E Deluxe
- processor: AMD Athlon 64 3400+
- ram: 2GB
- Video Card: NVIDIA GeForce 6800 GT
- sound_card: Sound Blaster Audigy 2 ZS Platium
- Hard_Drive_Capacity: 2 X 200GB
- Monitor/Display Make & Model: ViewSonic G90fb
Re: Switching from Organizer to Full Edit
I see what you mean, In fact minimizing them, then repeatedly changing back and forth from Full editor to Organizer, causes them to creep up the page. The only other alternative that I can find is to use Tabbed Documents, Window menu>Tabbed Documents. Then all you need to do is click on the tabs across the top to change from one image to the next.
