Using VS Pro X4, wide screen keeps coming on.
Mike Warren
motherboard: E7600 3.06 GHz 3.07 GHz
processor: Intel Core 2 Duo CPU
ram: 3.46 G Ram
Video Card: Built into motherboard
sound_card: Sound blaster Extreme X
Hard_Drive_Capacity: 1250 G
Monitor/Display Make & Model: Hanns.G, HDMI
Post by Mike Warren »
My project is NOT wide-screen. So I go to Settings and undo wide-screen. Everything is now fine. But, the next time I start up VS Pro X4, I find it has reset itself to wide-screen. Must I undo this each time I start up. I can't find anything in preferences that will keep it at my project setting. Regards, Mike
Re: Using VS Pro X4, wide screen keeps coming on.
Yep, if you want 4:3 then you must either manually de-select Widescreen from the settings menu, or inserting the first video clip into the Main video track. That is provided you have the option checked in Preferences to Show message when inserting first.... checked, and that will only work on video files that are of the format type that VS accepts as Project Settings, like MPEG-2 or DV AVI. In the past I've found that audio must also be present for this to work.
metmot
motherboard: Asus M2N SLI
processor: AMD Athlon 64 x2 Dual Core 6000+ 3.0 gh
ram: 8 GB
Video Card: Nvidia Gforce 7300se
sound_card: Onboard PnP Sound Device
Hard_Drive_Capacity: 1.7 TB
Post by metmot »
Ron P. wrote:Yep, if you want 4:3 then you must either manually de-select Widescreen from the settings menu, or inserting the first video clip into the Main video track. That is provided you have the option checked in Preferences to Show message when inserting first.... checked, and that will only work on video files that are of the format type that VS accepts as Project Settings, like MPEG-2 or DV AVI. In the past I've found that audio must also be present for this to work.
This is yet more new and annoying behavior with X4. Care to try and divine what the person who thought this was a good idea was thinking when they made the decision to default to widescreen on every new project? IMO it was yet another ill thought out "little" thing that people here keep saying don't matter. But they do. You get enough of it and your software becomes "third world". Taking away flexibility of preferences is almost never a good idea. Adding flexibility of preferences is almost always a good idea. Preferences that must be toggled to be changed are almost always the right idea. What's really silly is it used to be good and now it's been changed to bad and for what? Anyone?
John
msp7fan
System_Drive: E
motherboard: Gigabyte G690 - P35
processor: AMD Phenom II X4 - Intel Quad
ram: 4GB
Video Card: ATI Radeon 4650 512 MB
sound_card: Realtek
Hard_Drive_Capacity: 15TB
Monitor/Display Make & Model: EIZO Flexscan SX 2461W
Post by msp7fan »
Automatic "Widescreen" is not the only one, what disturbs me - but that only are two clicks.
What for me is a really mess, that you cannot override the videoformat in the project settings, when VS means to know the right one.
In addition, i would prefer to decide byself, if square oder non-square pixels are to render.
When i have that problem (and that happens often with recorded TV), i have to render that file with another program, where i can override the format.
Regards Martin
Mike Warren
ram: 3.46 G Ram
Thank you John! You said exactly what I wanted to say... but, just didn't know how to say it. Regards, Mike
