i keep geeting this message
any ideas on how to fix this.
unhandled exception
error number:0x80040706
Description: object reference not set
setup will now terminate.
photo explorer 8.5 will not install message inside
2log
re: photo explorer 8.5 will not install message inside
If you are using Windows 2000 or XP, make sure that you have "Administrator" privilages with your user account. Guest or Limited accounts will not allow Ulead softwares to install or run properly.
Also, Try copying the installer files to your hard disk. Then install it from there. This is to make sure that the installer cd is not damaged.
