VS9 and AC3 dolby digital
mzanchi
Post by mzanchi »
hi guys,
i have a problem, only ths one :-) i'm lucky person ;-)
my problem is the use of AC3 dolby digital code in my video
i try in many way but evry time i want to create mpeg with ac3 code, i recive an error from VS9 and creation process terminate without any files :-(
Same behavior in dvd workshop 2, if i use ac3 decode i have the same problem.
I come from vs8 pus ac3 pack installed, but i don't know if this is important
What can i check?
marco.
sorry for my english, do you understand my post :-) ?
THoff
Post by THoff »
I had similar problems with UVS 9 after uninstalling UVS 8 with the AC3 Powerpack. If you have the boxed version of UVS 9, go to the Control Panel, select UVS 9, then Change/Remove, and select "Repair".
mzanchi
Post by mzanchi »
Unfortuntly i don't have boxed version of vs9, i will try the same for my downloaded version :-) uninstalled and reinstalled
hoping works fine the same ...
thanks
Marco.
mzanchi
Post by mzanchi »
thanks THoff :lol:
you tip works fine... :-)
i have uninstall vs9 and reinstall without install before vs8 and ac3 pack
thanks again
marco
