screen capture
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
screen capture
I have PSPro X.Often when I capture an image, figures show which I presume is the image size measurements.What can I do to avoid these figures being seen in the screen capture target area.
wds937
- motherboard: Dell 0HN7XN A01
- processor: Intel Pentium Dual Core E5800 - 64-bit - 3.20 GHz
- ram: 4 GB
- Video Card: Intel G41 Express - integrated
- sound_card: Realtek High Definition Audio - integrated
- Hard_Drive_Capacity: 320 GB
- Monitor/Display Make & Model: ASUS VS247
Re: screen capture
Are the numbers actually getting captured? I presume you are capturing using PSP's screen capture feature. I tried this with PSP X in Windows 7 32-bit, and I could not reproduce the problem.
When dragging to select the capture area, the numbers you describe display on the screen to give you the dimensions (in pixels) of the capture area. However, they did not show up in the actual captured image. I tried capturing from PSP itself (using a second instance of PSP X), from its help file, and from the Opera web browser. Each time, the numbers were displayed, but they did not wind up in the captured image in PSP.
Ken Veal
- ram: 32 GB
Re: screen capture
Thanks for the reply.The numbers are not captured every time(XP).Iwil have to take note of my exact workflow next time and report back when the numbers are captured.When it has happened I have to use the clone brush to remove the figures.I usually use file-import-screen capture-start-right click at start point-left click(numbers show)-drag(numbers increase)-left click at desired selected area.I presume this is the only way to do it(unless you are using a 2nd instance of PSPro to capture the 1st screen capture.
