I am using Movie Factory 7 SE and love it. But it's been driving me crazy and cost me a lot of time recently. I am a fairly good computer/software troubleshooter but I just can't get a handle on this.
I have successfully made a .dwz file consisting of an .MPG video followed by a "color" slide with text on it inserted while in MF plus about ten .JPG photos. I've saved it, retrieved it, burned it to DVD, and viewed it on DVD players, at it has been fine.
Please note I used the *Edit Room" to create this file. I noticed on posts on previous versions of MF that you didn't used to be able to combine video and photos, but in MF7SE you can. It even gives you a mini-menu offering the insertion of videos, images, color (slide), and audio into the time line.
I tried multiple times to create a new slide show doing the same things as I did with the first .dwz file I created, with the same ingredients -- i.e., .MPG video and .JPG photos -- and believe it or not, each time it now deletes the slide show from the .dwz! However, while you stay in the .dwz everything acts fine, including the play button, preview, etc. There's absolutely no warning nor even a hint that anything is awry from MF's point of view.
But if you exit MF7SE you may never see your slide show again. The .dwz does open... but there's nothing on the time line. Just in case you're wondering, yes, I am certain I saved my .dwz after creating the slide show.
More detail: If you don't include a .MPG file, and have only .JPGs, then you will never see your slide show again once you exit MF7SE -- even though everything seems fine as you're working with the file. There's no warning that there's anything amiss. If you include a .MPG file at the beginning of your slide show, then you will see it after exiting and re-accessing MF7SE about 7 times but at the 8th time it will have disappeared.
I am astonished at this turn of events since my first such slide show effort had gone so well.
In the problem slide show there are many more .JPG photos than in the successfully-created .dwz -- about 90 to 95 photos. Is that too many?
Add Slideshow: I do not want to use the "Add Slideshow" utility because while it will let you add "color" slides, it won't let you write text on them! Unless I've missed something, whenever a "color" slide is highlighted, the "T" text option becomes grayed out! (Why in the world did they ever do that??)
I am running XP Pro and have plenty of disc and memory space.
I want very much to create this slide show of our week together for a friend I visited. Any help you can offer will be much appreciated.
Thanks,
Janet
