vs x12 no sound when i creating dvd
aradwan
motherboard: gigabyte
processor: intel 3g 2c 800b
ram: 2gb
Video Card: nivida 8400 gs
sound_card: Realtek
Hard_Drive_Capacity: 750 gb
Monitor/Display Make & Model: 21 lcd lenovo
Post by aradwan »
Hi every one
I do have an video cd contain an mpeg 1 file and I am trying to convert it to dvd PAL
I start the VS x12 trying to create a dvd but it is creating it without no sound so I try to make it as an iso file an I mount it to playing it in windows media player same problem the media player playing it without no sound so I tried to create an mpg2 file with 720x576 and 3500 constant video data rate Audio format :mpeg /stereo 224kb/s When I am doing this the mpg working very well with sound normally in media player so I try to create a dvd from this mpg file the same problem happen again the VS x12 create the dvd without sound
Any Idea why? Should I install any codec ?
Re: vs x12 no sound when i creating dvd
Post by Black Lab »
Please read the following and supply the requested info.
http://forum.corel.com/EN/viewtopic.php?f=1&t=8959
aradwan
ram: 2gb
sound_card: Realtek
Post by aradwan »
Operating System: windows xp sp3 32 bit
32 bit or 64 bit:
Motherboard: gigabyte 954 DNA
Processor: ntel Pentium Dual-Core Processor 3ghz 2m cash bus 800
Ram: 2 g.b ddr2
Video Card: navida 8400 gs
Sound Card: realtek
Hard Drive Capacity: 750 gb
System Drive: d:
Describe your problem: no sound after creating dvd
Properties of your source files, including video, audio, image files (format, file size, where did you get it?): format mpg1, 700 mb,VCD
What devices are involved and their mode of connection?:
Project Properties (important): mpg2 file with 720x576 and 3500 constant video data rate Audio format :mpeg /stereo 224kb/s
Output format (file, DVD, VCD, SVCD): dvd
Output Properties (cogwheel in lower left of burn screen): pal
i am using video studio X2 pro
i am not using any codec at all Except divx Version 6.4.0
Post by Trevor Andrew »
Wow not heard of VCD video in a long time, cannot even remember what files are on the disc.
I assume you have the video file on the timeline and that it plays ok, you can hear the audio?
Right click the clip and select proprieties, what are they?
Do Share Create Video File-DVD 4:3
This will render/convert the video to a compliant MPEG2 file
Does the resultant file play on Video Studio?
If yes use this to burn a DVD, Add Video
aradwan
ram: 2gb
sound_card: Realtek
Post by aradwan »
my source file is
video type :mpeg1
attributes: 24 bits , 352 x 288 , 4:3
frame rate: 25
data rate:1150 kbps
audio type: mpeg audio layer2
layer:2
attributes: 44100,16 bit.stereo
bit rate:224 kbps
my output file (after share in VS x2)
video type :mpeg2
attributes: 24 bits , 720 x 576 , 4:3
frame rate: 25
data rate: 3500 kbps
layer:2
attributes: 48000,16 bit.stereo
bit rate:224 kbps
the outpot file can be inserted to VS X2 without no porblem and play in in the VS x2 with sound
but the problem come when i share-create dvd
when i play the output dvd in media player i have no sound at all
also in my dvd player and the media player see no codes in the properties in the cahpter when it playing this dvd
any idea
How are you creating the DVD.
Rendering the VCD project creates a standard Mpeg 2 file which should be used to burn a disc.
You know the video file (output file) works cos it plays ok.
Start a new project, Empty timelines.
Share Create Disc
“Add Video” using the Mpeg2 (Output File)
The burn process should not be re-coded as it is a compliant video file.
When you finally hit the “burn” button the process should start with Convert Menu.
If you first see Convert Title then the Mpeg2 file is being converted, not what you want……..
To save wasting a disc create a DVD Folder to your PC’s Hard Drive, you should be able to play this to check quality. Then finally burn a DVD disc.
aradwan
ram: 2gb
sound_card: Realtek
Post by aradwan »
thanks for your answer trevor andrew
i do as you said adding the video (output file) in new project and use sahre- creating DVD
i chose no menu i see the VS X2 converting the mpeg2 file to DVD and i use (create iso file)
so after the VS X2 creating this ISO file i mount it and playing it in media player 11 from play menu- play VCD DVD
so the media player open the DVD play it but WITHOUT SOUND
so any idea
After creating the Output File, are you able to play this Mpeg 2 file and hear audio?
Please say yes……..
OK
Start a New project, do NOT add anything to the timelines....
Share Create Disc – DVD
This opens the Burner Module
At the top left select to Add Video—browse your hard drive for the Output File
Continue to burn a DVD or Image file.
Please download and install the VLC player
http://www.videolan.org/
Use this to play your video file.
Does it play with sound
aradwan
ram: 2gb
sound_card: Realtek
Post by aradwan »
yes
i can play my output file with sound int he media player
any yes the vlc player play my dvd with sound
on more question plase
why the media player play the dvd without sound?
If you're referring to Windows Media Player, the one that comes with your operating system, it probably has to do with what codecs it uses. I've made DVDs and WMP will not play them. It is somewhat proprietary, meaning it may not use the same codec that is already installed on your system. Another example is my mother's laptop. She could not get it to play DVDs, again talking about WMP. After some checking I found that I needed to purchase an DVD (MPEG-2) codec just for it.
I keep 3 or 4 different software media players installed just because of this. If one doesn't play it, I'll check my DVDs using another one. If I find that none of my software players will play it, I must have a problem with the DVD itself, and go looking at the various attributes I used while creating it.
aradwan
ram: 2gb
sound_card: Realtek
Post by aradwan »
thanks very mush for your help and support
