Hello,
At the "Share/Cerate video file/AVCHD" step, among the other types appears the following:
AVCHD (1920X1080P)
AVCHD (1920X1080)
Since I am dealing now with HD movies, I don't have any idea what is the difference between those types, so I am not sure what should I choose.
Any help will be appreciate.
Thanks,
Abraham
Types of AVCHD files
Re: Types of AVCHD files
The difference obviously enough is in the 'p' which stands for progressive. This means if you choose that option, your output AVCHD will be frame based, with each frame being a solid frame, rather than a half-frame interleaved with another half frame, coming out Upper Field First. In effect, progressive video is meant to be better than interleaved -- higher quality. But that usually applies to HD video which is running at 50 (or 60 NTSC) solid frames per second. There is a whole big debate elsewhere in this forum about how to get VS X4 to produce 1920 x 1080p video at 50/60 fps, given the increasing number of camcorders out there which film in that mode.
So the next question is whether you have such a camera. If not, then choose the option without the 'p'...
Natal
- motherboard: Asus P8Z77-V deluxe
- processor: i7 3770K 4.37 Ghz
- Video Card: Gigabyte GTX680 OC 2GB
- sound_card: System board
- Hard_Drive_Capacity: 40 TB
- Monitor/Display Make & Model: Samsung SyncMaster S27A850D (2650x1440)
The AVCHD (1920X1080) would be 60i, which is what most camera's shoot in. AVCHD (1920X1080P) is 30p.
On my camera you have the option of 60i, 30p or 24p. But, the progressive modes are actually recorded at 60i.
Canon Vixia HF G30; Sony RX100M5; Samsung NX1; Nikon P900
Videostudio X6
Creative Cloud CC
Videostudio X6
Creative Cloud CC
zehavi
- processor: Intel[R] Core[TM] i7-8700 CPU 3.20 GHz
- Hard_Drive_Capacity: 465 GB
- Monitor/Display Make & Model: LG
Thank you Ken and Natal,
In my camcorder movies are recorded with AVCHD 1920x1080/60i format, so please let me know what will be the best choice for me. I am still a little bit confused, forgive me for my ignorant in this subject.
Thanks again,
Abraham
Thanks again,
Abraham
Since you don't have a camera which films in 'p' mode, then as I said, use the output option which does not have the 'p'...
zehavi
Thank you very much Ken,
This is exactly what I am going to choose now.
Abraham
Abraham
Hi Abraham
You should also be able to choose Share Create Video File—Same as First Video Clip
If this option is available then your video files properties will be used to render the new video.
zehavi
Thank you Trevor,
Good to learn more.
Abraham
Good to learn more.
Abraham
The problems is, though, that it doesn't work with all HD video formats...
