Thanks in advance.
Colorize black and white photos
daddog
Tried a search in the help file in Paint Shop Pro X3, but could not come up with anything. Is that an option/tool it has?
Thanks in advance.
Thanks in advance.
aka James or dd :)
MB Gigabyte GA-EP45T-UD3P
CPU Intel 2 Duo E8500 3.16GHz
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
LiteOn DVD Burner SOHW-1693S
Sony HDR-CX550V camcorder
http://www.332nd.org/
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Colorize black and white photos
There is....and there isn't. It's not like the tool was designed for black and white colorization but it can be used that way.
Of course there are lots of other options that give you a lot more control as well.
The tool itself is called the Change To Target Brush: http://www.youtube.com/watch?v=5HAQOmISNgM
You can see how I used the tool in that tutorial. Unlike the method I'm going to describe next, the Change To Target brush requires that you paint directly on the image. This changes actual pixels and may or may not ruin things. So while it's possible to use this tool only there are better more flexible methods.
If you use this tool I recommend you duplicate the layer first so that you're not working on the original in case something goes wrong.
This next method is more common among the different programs.
Create a new raster layer above the image. Change the blend mode to either Color or Burn (You can try others but these two are the most recommended).
Now grab the color you want to color with and with the paint-brush start painting on the new raster layer. You'll see it take on the color that you give it, and it's actually recommended that you create a separate raster layer for each color so that you can make changes to it quickly using any of the color adjust options.
Doing a quick search on YouTube I found a tutorial that shows this method fairly well: http://www.youtube.com/watch?v=x-WHb2I93YQ
Quick note: I don't recommend using the Merge option until you're done....or at all really. Save a copy as a PSPImage so that if you want to come back and make adjustments later you can. And also save out a copy as a JPG and this will do the merging for you. This way you don't ruin the actual image, and if you screw up you can fix it as you go.
daddog
Thank you for your time. I appreciate the detailed response.
I will check those out.
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
Simone Corel UK
- Alludo
@ LeviFiction
I'm always surprised and full of respect for how our users work with our software. While reading the question, I immediately thought the same as your second video link shows. Your video shows the "Charge to Target" tool and I admit, I have never tried it before. Many thanks for your video
