Mixing type 2 DV with other file formats
qtrim
motherboard: ASUS P5QL PRO 775 P43
processor: Intel Core 2 Quad Processor Q9550 2.83GHz 1333MHz
ram: 4GB
Video Card: NVIDIA GeForce 9400 GT
sound_card: Onboard Asus Audio
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Samsung T260HD 25.5-Inch LCD
Post by qtrim »
I had a time where I shot some home videos on my old Sony DV camera (type2 DV 29.97fps) and also some on my other digital cameras of various models which recorded in mjpeg (20fps), h.263(30fps), mpeg4sp (29.97fps), and even a few .asp. I want to combine all these in chronological order on DVD. But I worried about which format to choose when rendering such a mixture, since I've heard that type 2 DV should be lower filed first. Will that mess up the way the other files are rendered? I was wondering if i should render the DV out to DVD compliant mpeg2 first and then add in the others in another project. Suggestions welcome. Thanks.
Using VideoStudio since old Version 7. Currently using X10.
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Re: Mixing type 2 DV with other file formats
Post by skier-hughes »
Personally I'd convert them all to the same file type, then edit them.
If it's going to dvd, then make it mpeg2 as your file of choice.
Post by Trevor Andrew »
If you were to edit each video type in a separate project you could create separate Mpeg2 files for each having the correct frame order.
Adding these to a DVD as individual titles should work, even though they may have different field orders.
Its really how long each will be and whether its feasible to have separate titles.
If you need to combine to a single file then again edit individually and render to a common Mpeg2 settings. Its this format that is needed to burn a DVD.
You may find that some of your video clips use Frame Based which can be converted to either field order.
