Errors :cry:
wildcardz
Errors :cry:
Post by wildcardz »
Ok,
Before everybody starts jumping my case :D I have spent most of the day today searching and reading this forum including the PROCEDURE post.
I printed it and followed step by step. When attempt to burn the disc, it still gives me the error about not reusing the convert cache. I cannot figure out what it could be trying to convert. I created the video file and I do not load anything that I know of that would need to be converted.
I simply start the program (VS9) go to share / create disc and the add video. Now I do create chapters and the chapter menu within the "Create Disc" screen.
ANY Help would be appreciated.
Thanks :shock:
jchunter
Post by jchunter »
Are you sure that you are manually setting the burn properties (tiny gear-shaped icon located second to the right on the lower left of the Create Disc window) to exactly match the video file properties?
John
wildcardz
Post by wildcardz »
:oops: :oops: :oops:
I had not changed the sound setting from dolby to mpeg.
jchunter wrote:Are you sure that you are manually setting the burn properties (tiny gear-shaped icon located second to the right on the lower left of the Create Disc window) to exactly match the video file properties?
John
maddrummer3301
Post by maddrummer3301 »
That shouldn't matter,
You probably want Dolby audio anyway, but the program may be
having a hard time with the mpeg audio you recorded and can't convert
the mpeg to dolby.
Also, exit VS and delete all the files in your home/temp directory by
running the windows cleanup utility.
There is also a VS preview directory on the last tabl of preferences (F6).
Make sure that directory is cleaned out for a new project.
MD
