Adding nodes to vector circle?
menura25
motherboard: Gigabyte P31-S3L
processor: Intelcore 2 Duo
ram: 2GB
Video Card: NVIDA Gforce 8500
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 400
Monitor/Display Make & Model: Viewsonic VX1932
Post by menura25 »
I have a layer with a vector circle. I only want to use a segment of the circle. Placing the cursor on the circle does not give the +ADD. How can I put some nodes on the circle so that I can delete the rest?
Peter
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Adding nodes to vector circle?
Post by LeviFiction »
The ellipse is it's own special kind of vector that only allows you to set the X and Y radius for the circle. As a result it will always have four nodes.
If you want to add or remove nodes from the circle you have to convert it to a path. Paths, what the Pen Tool creates, are the ultimate flexible vector. To do this select the ellipse and go to the Objects menu and select "Convert To Path" once it's a path you can add and remove nodes using the Pen Tool.
menura25
ram: 2GB
Post by menura25 »
Just what the doctor ordered
Peter
