Along with my purchase today I had PaintShop Photo Pro X3 Project Creator - when I went to install it - it requires a serial number which was not in the e-mail I received with the other serial numbers.
Would someone mind pointing me in the right direction to obtain one please?
Thank you,
Anita
df
- ram: 64gb
- Hard_Drive_Capacity: 1 Tb
Re: PaintShop Photo Pro X3 Project Creator
Your serial number for PSP X3 should have unlocked the Project Creator when you installed PSP X3. As far as I remember you didn't have to input a separate number after PSP X3 was activated. Maybe try restarting your computer if you haven't done so by now.
Regards, Dan
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Try using the same serial number as PSPX3. For me installing the separate Project Creator application actually started up the PSPX3 installer and that's what I had to do. Even if it isn't starting up the PSPX3 installer still try the same serial number because they do belong to the same package.
Simone Corel UK
- Alludo
@ Anita_N
Please make sure that you type the number correctly. It's a very long complicate number and we all need help form time to time: somebody spells and I type.
If you have PSPPX3 (standard) already installed, the Project Creator shouldn't ask for a serial number. If you have PSPPX3 (as part of the Ultimate box), then use the same number for the Project Creator. It works. I myself tested it.
Anita_N
- processor: Intel Core 2 Quad Processor Q8200
- ram: 4GB
- Video Card: Intel GMA X4500 Intergrated
- Hard_Drive_Capacity: 640GB
- Monitor/Display Make & Model: View Sonic VT2300LED
So sorry for not having got back sooner.
After I had been doing some work in PSPX3 and closed the program I thought I would try installing the creator again - the first time it failed but decided to give it another shot and it worked
The creator is more curiosity for me than anything as I make all my own things including brushes but I thought it would be nice to take a look at.
Thank you so much for all your help - it is really appreciated.
Anita
Anita
