fonts
mike19
fonts
Post by mike19 »
how can i add fonts to pi 5?
keenart
Post by keenart »
That would depend on which Operating System you are using PI 5 with.
Typically you will find the Font Folder under Windows, i.e. C:\WINDOWS\FONTS\.
PI should use the fonts in the Windows Fonts Folder. If you want to install a font into the Windows Fonts Folder, you can copy the font to a Temp folder, right click on the font name and on the Menu Item Dialog List select Install Font, and the font will be installed to the proper Folder. If it is not a True Type or older font that contains two parts you may have trouble installing that particular font. If which case you will have to obtain an updated version of the font.
PI should find the font the next time the program initializes.
