It's an element contained in a .vsp
Right now I'm trying to "connect" & render 1 video file + 4 .vsp (inttertitle card.mp4, segment1.vsp, ... segment4.vsp). Each contains segments that run continuously and I need to combine into just one video file (mp4 HD format). But every time the render reaches that file (above) (17% of the total render), it crashes. There's nothing else on that timeline except that mp4 file and a wav file.
I don't understand why it's happening. I have done it successfully before in Youtube HD format.
SmartProxy is enabled, but I don't see how that's relevant to rendering.
I have tried re-converting the video file into versions: one has .mpeg4 codec, the other has .H264.
I also downloaded & installed VSPX4 SP1, updated my codecs, drivers, downgraded Quicktime. But the result is still the same as far as rendering the whole project goes: crashing at 17%.
There were enough RAM & CPU when I did the rendering so I don't think this is a hardware issue.
I also tried disabling SmartRender just to see if it will react positively.
There came a time also when the render passed 17%, but it crashed when it reached 94%.
Interestingly, when I rendered segment1.vsp only (to mp4 HD), it also passed 17%, but then it failed to finish also.
Right now, I'm going to re-convert the file to a different format to see if the whole crash is related to mp4 (which is kind of confusing because I have rendered many mp4s just last week and they were successful).
So I'm curious, is there a limit to how many "connected" .vsp files one can render successfully?
And is there a certain mp4 type that VSP can't handle properly?
Thank you in advance.
-AJ
