How to reverse the visual effects in VS 13 ?
For example: I put blur effect on clip and it works like normal picture becomes blur picutre, and I want to change it like blur to normal one.
Is this possible to do in VS ?
regards
Videostudio Reverse Visual Effects
Re: Videostudio Reverse Visual Effects
Welcome to the forums,
You should see a Customize Filter button. Press it, and in the dialog that opens, you can add more keyframes. They will always have at least 2. You can change the parameters on the keyframes. There's also a Reverse button, that basically changes the order in which the filter "plays" the keyframes...
Click on the image to enlarge
