Rob,Rob717 wrote:After VideoStudio crashes have you checked the Windows Event Viewer?
What you are looking for in the event viewer is the faulting module, the faulting application should be vstudio.exe and then a version number 14.0.0 (or something like that.)
Post the info and that will help troubleshoot the issue.
the info given there is not really helpful ==> vstudio.exe
But the reason for the crashes during rendering i got explained from Yvonne and had posted that some posts before.
http://forum.corel.com/EN/viewtopic.php ... 07#p223107
A known bug in the (windows) memory management, what appears with complex video files especially when rendering to AVCHD. In 32-bit Systems the error appears earlier around 1 GB memory consumption, in 64-bit environments at least on a 2 GB memory limit.
Corel seems to work on a fix to bypass such limitations given by the Gates-boygroup (remember on earlier days: Nobody will have a need for more than 640 KB memory
On the other hand, a lot of programs use numerous Gigabytes of RAM without any problems.
My other problem with very long frozen and very slow behavior of vstudio, when some Smartsound files are in action, seems to need another fix, as known about years (see above link).
Perhaps Yvonne can give us a statement to that problem.
