Apply same effect to multiple clips
qtrim
motherboard: ASUS P5QL PRO 775 P43
processor: Intel Core 2 Quad Processor Q9550 2.83GHz 1333MHz
ram: 4GB
Video Card: NVIDIA GeForce 9400 GT
sound_card: Onboard Asus Audio
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Samsung T260HD 25.5-Inch LCD
Post by qtrim »
I have a project with multiple images dropped on an overlay track. After I've placed them all, I'd like to apply the same fade out effect to all of them at once. I've tried shift/click and crtl/click to select more than one, but it doesn't work. Any solution?
VSX4
Using VideoStudio since old Version 7. Currently using X10.
Re: Apply same effect to multiple clips
Post by Black Lab »
In Preferences, set that transition to be the default.
Post by Trevor Andrew »
Do you mean the fade effect using the Direction and Styles under the Options / Attributes tab :?: :?: :?:
If yes, right click a clip and select Copy Attributes, then paste to the other images, Shift + Click will select multiple images, then Paste Attributes
