Overlay track resize
budbon
- motherboard: Intel OEMD975XWT2G1AAD3346-107
- processor: 2.80 gig Intel Premium D
- ram: 4 GB
- Video Card: NVIDIA GeForce 6600
- sound_card: C-MediaPCI Audio
- Hard_Drive_Capacity: 2749.84 Gi
- Monitor/Display Make & Model: Samsung 8000:1
- Corel programs: PSP X8, video Studio Pro X9
I am using photos for a slideshow. How do you resize a photo or video on the overlay track to the exact size on the timeline? I know you can use the resize handles but is there a faster way?
Bud Kerr
VSP X9
PSP X8
VSP X9
PSP X8
Re: Overlay track resize
Right click in the Preview Window and choose Fit to Screen. You can also choose this as the default in Preferences.
Jeff
Dentler's Dog Training, LLC
budbon
- ram: 4 GB
The also choose Keep Aspect Ratio.
Jeff
budbon
- ram: 4 GB
What do you mean it didn't work? Either it is the same aspect ratio or it's not.
Jeff
If you use images that are not the same aspect ratio as the frame, nowadays most use 16:9.
When you re-size and keep aspect ratio the image will fill the screen but look as though you have zoomed in, loosing some detail at the edges. Especially if they are portrait sizes.
If you use images that are 16:9 then they will fill the screen and look ok. Assuming you are working with widescreen
You have to resize manually by dragging the corners, this will keep the image in proportion.
Do not drag the green square this will distort the image.
Once you have resized the first image, right click and select Copy Attributes.
Paste to other images, Use Shift + Click to select multiple images.
Ok I have had a thought………….
Generally I copy and paste attributes across the overlay track, but you can copy and Paste attributes from the top track to the Overlay track.
This may be your quickest option.
Take care that the images are using the same aspect ratio?
budbon
- ram: 4 GB
The aspect ratio must be the problem. I am using a slideshow I had made earlier. I usually make a DVD file using Share, Video File, DVD (16:9). Do I need to share them as 4:3?
Bud Kerr
VSP X9
PSP X8
VSP X9
PSP X8
whats the size of your images in pixels
right click an image and select properties , what are they
budbon
- ram: 4 GB
What is?????? is that the project properties you are talking about.budbon wrote:It is in a 16:9 video format now.
Did you read my reply regarding the image sizes.
I will have to leave shortly, Tuesday night is bowling night
budbon
- ram: 4 GB
The images I made the slideshow from are 3168 X 4752 pixels.
Bud Kerr
VSP X9
PSP X8
VSP X9
PSP X8
budbon
- ram: 4 GB
The slideshow (in DVD format) shows 1:33 to 1:00 aspect ratio.
Bud Kerr
VSP X9
PSP X8
VSP X9
PSP X8
that's 4:3 - NOT 16:9 - and your images appear to be 1.5 to 1.0 - - if you are using 16:9 for your project properties and try to fill the screen then of course they will distort.
16:9 should show an aspect ratio of 1.77 to 1.00
To avoid distortion and completely fill the screen your images must be in the same format as your project - or you do not fully fill the screen and have black borders at each side
budbon
- ram: 4 GB
Thank you, In future projects how should I set up my slideshows in order not to have this issue? Again my photos are 3168 X 4752 pixels (if that matters. I guess my question should be am I saving them in the wrong DVD format (16: 9)?
Bud Kerr
VSP X9
PSP X8
VSP X9
PSP X8
