VideoStudio Pro X3 and GoPro HD Files
Blairc
- motherboard: NP-R580-JBB1US
- processor: Intel Core i5 M 430 2.27 Ghz
- ram: 4GB
- Video Card: NVIDEA GeForce 310M
- Hard_Drive_Capacity: 500GB
VideoStudio Pro X3 has been crashing on me when trying to edit MP4 1080p files larger than 4 GB from my GoPro camera. I keep getting an "Unspecified Error" message. It's possible that my laptop just doesn't have the capacity to handling editing of those files, but is anyone aware of a glitch in VideoStudio that could be causing the problem? Thanks.
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Re: VideoStudio Pro X3 and GoPro HD Files
If the processor of your laptop is Intel Core i5 M 430 2.27 Ghz, then it's more than enough to handle MP4 1080p files larger than 4 GB. Can you tell me if the error happens during the editing process or burning process?
For the meantime, I suggest that you download all updates for your VS X3 by going to http://www.corel.com/servlet/Satellite/ ... 0460544373.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
Blairc
- ram: 4GB
Thanks for the quick reply.
It happens during editing. A dump file is generated, but I was wondering if anyone else had a similar experience before I try forwarding the dump file to Corel Tech Support.
I have downloaded and installed all available updates for VS X3.
I have had similar problems with my GoPro files and some that X3 would not accept at all ( had to convert to mpeg-2 first ). I also have had a similar issue with files from my Canon HV30 during timeline playback. What I do is only play a short portion of the edited region which seems to work ok, my crashes alwasy occur after the playback has been going for a minute or two. Once all editing is complete I create the final output ( disk or file ) which has always worked ok.
Blairc
- ram: 4GB
Thanks for the suggestions Trevor. I tried going to the older version of Quick Time but that didn't help. I will give your other suggestion about the reinstall with and without the service pack a try as well.
I can work with the file if I convert it to another format first. That's just annoying to have to do. My crashes occur shortly after I try to playback the clip or if I try to make an edit to the clip. The playback isn't smooth either and has snow in it. I don't have issues working with the 720p or 920 p files from my GoPro, but I can't work with 1080p files.
The installation of X3 without the patch was to cure a specific problem with Mov playback, not X3 crashes. Although it won’t harm try a re-install.
There have been other users having problems with GoPro video, have you searched the forum???
Unfortunately I do not think they found a solution other than to convert the video.
