VSX4 Freeze or Audio Encode Problem
banzemanga
Post by banzemanga »
So i have this video that i am trying to edit and save the changes. I want to save it in the same formatting as the original source so i selected "Same as First Video Clip."
Before saving, if i look at the options and leave "Perform SmartRender" on, the program will freeze rendering at 9%.
However, i if i don't perform SmartRendering; it will give me the error "[2000:1:1] failed to encode audio."
Here is the original encoding of my video:
General
Complete name : D:\pro1\Chapter13.M2TS
Format : BDAV
Format/Info : Blu-ray Video
File size : 6.71 GiB
Duration : 23mn 41s
Overall bit rate : 40.6 Mbps
Maximum Overall bit rate : 48.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=2, N=26
Codec ID : 27
Duration : 23mn 41s
Bit rate mode : Variable
Bit rate : 37.4 Mbps
Maximum bit rate : 39.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Bits/(Pixel*Frame) : 0.602
Stream size : 6.19 GiB (92%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Menu ID : 1 (0x1)
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Muxing mode : Blu-ray
Codec ID : 128
Duration : 23mn 41s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 260 MiB (4%)
