Corel Pro 3x- audio cuts in and out during playback
wohlman1
motherboard: Hewlett-Packard 144B 65.35
processor: 2.53 gigahertz Intel Core i5 M 460
Hard_Drive_Capacity: 573 GB
Monitor/Display Make & Model: Generic PnP
Post by wohlman1 »
When I play the video "clip" mode, it is perfect. When I play the "project" mode, the sound cuts in and out. But not on all clips, just the .mov files. The .wav are fine. I just updated all the patches, (to my knowledge) and tried to make a new project.
I just figured out the the corel does not like .mov files. I converted to .wmw and it works. Is there a fix for this...
Re: Corel Pro 3x- audio cuts in and out during playback
Post by Black Lab »
There has been an issue with .mov files and the version of Quicktime that is installed. Try a search for it.
Post by Trevor Andrew »
does it look like this!
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Post by teknisyan »
What version of VS are you using? Most likely a codec issue for MOV. You may need to install the appropriate version of QT on your computer. You can visit http://support.apple.com/downloads#quicktime, for the different version of QuickTime... you may need to first check the current QT version that you have the go one version down...
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
The last time I installed the latest version of Quick Time Video StudioX3 crashed.
So installing an earlier version should help………
Unfortunately this may affect I-Tunes????????
I am now using QT 7.5.5, I know its old but this version is provided with X4 installation file?
If you need to revert to 7.5.5 http://support.apple.com/kb/DL26
If you still have problems after trying Quick Time, re-install X3, do not install the service pack.
Does it work, install the service pack, does it work???
I have to say I no longer use X3.
