Frame size does match and therefore can't trim
marshalab
motherboard: A416130852
processor: 2.30 gigahertz Intel Pentium Dual-Core
ram: 2816 Megab
Video Card: NVIDIA ION
Hard_Drive_Capacity: 300gb
Monitor/Display Make & Model: 21.1"vis, s/n 66377441
Post by marshalab »
1. I am using the latest version of videostudio which I upgraded today today June 11, 2011.
2. I am using a Sanyo Video Camcorder PD2, which I am recording in 1280 x 720 29.97 frames per second.
3. I’ve imported the video, into the program, and I am simply trying to “join” the video by using step three that is “Share.”
4. I am clicking option “create video file” and then the option “same as first video clip” because I would like to preserve the same video settings. There are other ways I could join the clips, but these ways do not preserve the video settings. So when I choose “same as first video clip I get my error message “The frame size of the video (1280 x 720) does not match the settings and therefore cannot be trimmed.’
I am hoping you can help me.
Sincerely,
Marshal.
Re: Frame size does match and therefore can't trim
Welcome to the forums Marshal, :)
Can you right-click on one of the video clips in the Library or Timeline, select Properties and post them? I only have a couple of clips that are similar to yours and each time I select the Same as First Video clip option, I don't get any error, and VS produces a video file with the same properties. The difference may be the codec being used. My clips use the H.264 codec contained in an MPEG-4 wrapper. Yours however may be AVCHD which are different.
The Properties of my Video Files:
File Format: MPEG-4 File
File Size: 103,210 KB
Duration: 2001.168 seconds
Video
Video type: H.264 High Profile Video
Total Frames: 59,975 frame(s)
Attributes: 24 bits, 1280 x 720, 16:9
Frame Rate: 29.970 frames/sec
Data rate: 262 Kbps
Audio
Audio Type: MPEG AAC Audio
Total Samples: 88,253,440 Samples
Attributes: 44100 Hz, 16 Bit, Stereo
Bit rate: 157 Kbps
The properties when selecting Same as First Video Clip:
NTSC drop frame (29.97 fps)
MPEG-4 Files
24 bits, 1280 x 720, 29.97 fps
Frame-based
Data Rate: 262 Kbps, 16:9
MPEG AAC Audio: 157 Kbps
marshalab
ram: 2816 Megab
Post by marshalab »
Hi Ron,
Many Thanks for the Warm Welcome. So I have my data and here it is:
File format: mpeg-4 file
File size 22.752
Duration: 19.01 seconds
Video type h.264 baseline profile video
Total frames: 540
Attributes: 24 bits 1280 x 720 16:9
Frame rate: 29.970 frames/sec
Data rate 9871 kps
Audio type: mpeg aac audio
Total samples 872.448 samples
Attribntes 48000 hz 16 bit stero
Bit rate 256 kps
I hope that helps! Me!
Marshal :)
marshalab
ram: 2816 Megab
Post by marshalab »
Hoping to get a nice reply here. One possible solution is perhaps I could send some small video clips to a helpful person, and they could help me figure out why I am having this problem. I sure would like to keep my original settings in my processed movies.
Sincerely,
Marshal.
JeniferThomsan
System_Drive: D
Post by JeniferThomsan »
I am also using latest version of videostudio which i upgrade 1 june 2011. there is no problem arise which you said.
I think may be this problem due to upgraded, you again upgrade it.
