Image Stretch In VS Pro x3
hrpufnstuf65
Post by hrpufnstuf65 »
Hi all- been awhile. Hopefully someone can help! I DJ for fun on the internet, and I made a little video commercial, where I show album covers, with intermittent quick videos of me in- between. Since I changed locations where I DJ now, I took the original video, and just tweaked it a little with the new internet address, etc. The album covers I used were all originally 300x300, and I have them all centered in the overlay screen.
The problem is, when I play the video within VSx3, everything looks fine- but as I'm encoding into a .flv file to upload on youtube, it's distorting all the perfect "squares", and "rectangulizing" them the long way. Any ideas? Any help is greatly appreciated!!!
Re: Image Stretch In VS Pro x3
Post by Trevor Andrew »
What is your project properties? are you using 4:3 or 16:9?
When you convert to FLV are you using 4:3 or 16:9, what are your flash settings?
If you use widescreen then you would have to create your own template.
Things to try.
1 / disable Non-square Pixel Rendering (Project Properties-Edit tab)
Then reset the image size in the overlay track
Also from Share Create Video File – Flash--Options, uncheck Non –Square Pixel Rendering.
2/ You may be best to convert the project to a more suitable video format, maybe DV-Avi then convert that to Flash.
hrpufnstuf65
Right on, trevor- will try. I'll check the properties and see what tey're set at. I just don't remember this happening last time!!! Will update- thanks again!!!
trevor andrew wrote:Hi
Things to try.
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Post by teknisyan »
Another suggestion that you can try is to create a video file like mpeg or mpg via SHARE > CREATE VIDEO file of VideoStudio X3, then directly upload that file to Youtube, since Youtube support a wide variety of video format.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
