VideoStudioPro X4- How change the language
alain141
motherboard: AsusTek P5KPL-SE
processor: Intel pentium 4 530
ram: 4 Gigas
Video Card: ATI Radeon HD 4300 4500 series
sound_card: Creative XFi
Hard_Drive_Capacity: 364 gigas
Monitor/Display Make & Model: acer
Post by alain141 »
Hi !!!!
For an unknown reason, the current language (initially french) has been changed (now english). How could I change it, I don't find anything in the settings. Using the DVD to repair or reinstall the proramm doesn't work. A white screen is displayed then disappear and so one, slowly flashing.
Windows 7 SP1 Home edition 32 bit
Thanks for your help !!!!
Re: VideoStudioPro X4- How change the language
Post by BrianCee »
See if this article from the Corel Knowledge base helps you :-
http://corel.force.com/index/articles/e ... 000000L0Cv
alain141
ram: 4 Gigas
Post by alain141 »
Thanks for your feedback but the u32comm.ini (to change with the knowledge base attachment file) doesn't exist in my videostudio programm folder.
Post by BrianCee »
maybe that is your problem - - I found my copy of that file in C:\Program Files\Corel\Corel VideoStudio Pro X4 -- perhaps you should download the file and put it in the same place on your computer.
alain141
ram: 4 Gigas
Post by alain141 »
Hi Briancee !!!
Could you repeat the link. On the post it is cut after proX4.
Thanks for your helpfull reply!!!!
alain141
ram: 4 Gigas
Post by alain141 »
Sorry Briancee !!!
Finally, I found the u32comm.ini file into the folder: 8.48 ko 2010/11/17),same size as the downloaded attaachment file. Is my own file most recent ??? How manage the change. ??
Post by BrianCee »
here is the link again - not quite sure why you need it the link in my post above still seems to work.
Just do as the article tells you - download the file in that article - move the file in your VideoStudio programme into a temp folder somewhere on your computer, and then copy the new file in to the VideoStudio programme folder.
I do not know if you have the latest version or not - just try it and see if it solves your problem - if it does not then we can look further into it - but unless you try we will never know if it solves your problem
alain141
ram: 4 Gigas
Post by alain141 »
Thanks for your detailed explanation.
Change done (downloaded file put intoo the VSProX4 folder, instead the other)
Launching the programm, the language is again english (instead french)
When I installed the programm for the first time , I got the right one (french)
The change occured afterwards without any reason.
As I try to reinstall the programm (choice VS install), I get a white rectangle very slowly flashing, difficult to delete.
The associated process is setuparp.exe
Post by Black Lab »
alain141
ram: 4 Gigas
Post by alain141 »
Hi Jeff !!!!
Fantastic Idea !!! . Following your advice, I've update VSPro X4 with the SP1. Now I get everywhere the french language except on the control bar at the top of the screes :
File, Edit, Tools, Settings, Capture, Edit, Share
instead
Fichier, Edition, Outils, Parametres, Capture, Edition, Partage
I am now living a dream !!!!
Alain
