Regarding X3, I've read posts concerning crashes caused by "preview on image" being checked and used while making adjustments. Yup, I'll buy that, considering it happens almost every time I forget to uncheck that box. Here's a screen shot from earlier, but it may be hard to read since I had to resize it due to posting limitations.
If I've saved my file at regular intervals, there's usually not that much lost as far as data. But sometimes, the program won't even launch until the computer is restarted. With several other windows and projects open, that my friends is a Grade "A" pain in my big fat rear. Nevertheless, the main problem here is X3's inability to function as stable software. PSP is a great program....when it works.
PF
more crashing
Papa Fisheye
- processor: INTEL CORE i7-930 8MB L2 CACHE 2.80 GHz
- ram: 12GB
- Video Card: ATI RADEON HD 5770 1024MB GDDR5
- sound_card: REALTEK USB 2.0 CARD
- Monitor/Display Make & Model: DELL S2409W LCD MONITOR
dacar
- ram: 4gb
- Hard_Drive_Capacity: 1 tb
- Monitor/Display Make & Model: Dell 24"
Re: more crashing
I have similar problems. I have X3 - clean install, all latest patches and updates - but it crashes often. It seems to happen when I am adjusting anything on the Brightness & Contrast submenu. I get a message from Windows saying the program has stopped respondinig and Windows is searching for a solution. It never finds a solution and I have to restart PSP. At least I have learned to se my work in progress very often!
Anyone else having this problem?
Anyone else solved this problem?
(Dell Studio XPS 7100, Win 7 Home Premium 64-bit Service Pack 1, AMD Phenom II quad-core processor, ATI Radeon HD5450 graphics card, 8 GB RAM)
Papa Fisheye
- ram: 12GB
Re: more crashing
I managed to work for an hour and a half yesterday, with no crashes. I simply used the preview window on every command that has one, including ones I never used to: contrast, saturation and local tone adjustment. I'd much rather see the adjustments on the image itself as near to full screen as I can have it, but if all I have to do is use the preview window to eliminate the majority of program crashes, I'll get by.
PF
PF
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Re: more crashing
@Papa, you may want to perform a manual uninstallation then reinstall the program using your disc or redownnload it from your corel account, then download all updates from http://www.corel.com/servlet/Satellite/ ... 9872271743
To manually remove the program: http://corel.force.com/index/articles/e ... oto-Pro-X3
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
gning
- motherboard: AMD 785G chipset
- processor: AMD Phenom II X4 [B95] 3.0 GHz
- ram: 4 gb
- Video Card: on-motherboard Radeon HD 4200
- sound_card: on-motherboard Realtek
- Hard_Drive_Capacity: 384 gb
- Monitor/Display Make & Model: LG Flatron L246WP (24" S-PVA)
Re: more crashing
Just be glad you're not still using PSP 8... under 64 bit Windows 7 that thing would crash if you so much as try to drag a crop area. X3 only crashes like two percent as often.
paulaann15
- motherboard: Belarc Advisor
- processor: Intel processor Pentium 1.7GHz
- ram: 512 MB
- Video Card: Belarc Advisor
- sound_card: Belarc Advisor
- Hard_Drive_Capacity: 92.9
- Monitor/Display Make & Model: Toshiba Satellite
Re: more crashing
I have a new install and I have installed all the updates. I still get this message: Unhandled exception code 119. Command could not complete because there is no active document. I'm usually trying to edit photos in the express lab. I get done with one or two and it crashes.
