I have a DVD I am trying to create and very time I hit burn it takes for ever at 45%. I even tried waiting overnight and sure enough it just hangs. I tried creating it from scratch again and sure enough it hung.
Is there away (besides trial and error of removing files) to tell what is causing this?
I shoud mention that when creating the menu items, it states creating 1/2. IN fact there are three main menu's.
File causing problems when authoring
hot
M/F 4
Hi if its M/F 4 you are using when you capture video or slideshows you need to convert to export the movie "as fast export dvd compliant "
So when your 1st capture is in right click on it and then hold down ALT+Kbuttons, note where it is saving then after the procedure delete the first video capture, and then bring in the saved fast export one. this is necessary for slideshows others it will just hang when burning
I had same prob and this solved it. best john
