I bought VSX4 about a month ago and run it on a Windows 7 computer.
I have been working on a project that has several audio tracks.
When I burn a DVD directly from the project, the audio gain adjustments do not work right so there are volume problems on the DVD. It gets louder or softer as it plays ... unlike the project when played.
When the project is saved as an mpeg file, the audio goes out of synch. The gain is no longer a problem but the sound starts out fine but gets progressively more and more out or synch as the DVD plays.
As I looked through the forum , I noticed that someone else has a similar issue with a different version. It was suggested to get a patch download,
Is there such a patch for VSX4? ... or am I just doing it wrong?
DVD Audio Issues
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
Re: DVD Audio Issues
Any patches for previous versions would be built in to newer versions.
What type of audio did you use in your project?
MP3 files cause all sorts of problems.If you've used MP£, try converting these files to WAV and having another go, does it make a difference?
http://www.myvideoproblems.com/Tutorial ... o_WAV.html
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
There are no updates or patches for VS X4 yet but if you are working with different audio format, you may want to update the codecs on your computer. Here are some of the codecs that you may want to install.
RealPlayer: http://www.real.com/
DivX: http://www.divx.com/en/software/divx-plus/codec-pack
XviD: http://downloads.xvid.org/downloads/xvidcore-1.3.1.zip
Windows Media Player: http://windows.microsoft.com/en-US/wind ... dia-player or just download the Windows Encoder at http://www.microsoft.com/expression/pro ... rview.aspx
QuickTime: http://www.apple.com/quicktime/download/
Direct X: http://on-msn.com/aLrk0j (WinXP)
Direct X: http://www.microsoft.com/Windows/window ... tx-11.aspx
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
