Hello folks.. Quick question..
I created a rectangular outline and fille the rectangle with a color. How do I remove the outline of the rectangle?
Newbie - How to remove outline?
Radim
- ram: 4GB
- Monitor/Display Make & Model: 27 inch
Re: Newbie - How to remove outline?
Switch border color to NONE / dissable it.
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
The border/outline/stroke is defined by the "foreground" color on the materials palette. You can double click the vector on the layers palette to bring up its properties. You can right-click it and select "properties" from that menu and change the color in the properties dialog.
You can also grab the rectangle tool and select "Edit Mode" from the tool options and then disable the foreground color or decrease the stroke width on the tool options.
Lots of ways to approach the problem.
Of course those are only or removing the stroke on an object that you've already drawn. If you re-draw it then simply turning off the foreground color on the materials palette or setting the stroke value to 0 will get rid of the border/outline.
