Problem with installing Ulead F/X for GIF Animator
GIF Animator, SmartSaver Pro, Plugins, Applets....
Jlowi
Post by Jlowi »
Greetings to all;
I've purchased and downloaded Gif animator 5 and Ulead F/X for GIF Animator :D
Installation with gif animator was Successful. But, the Ulead F/X for GIF Animator keeps telling me that I need Gif animator 2 or above! :cry: :cry:
Please respond
Thanks in advance
Notebook specs:
Acer Ferrari 3000
bryave
try reinstall GIF 5
Post by bryave »
Why don't you try a clean reinstall of GIF 5? Try removing folders related to it in program files, registries, installation info, and delete temp files before you install it again. Please let me know if it worked. ^_^
†bryave
Redline
Post by Redline »
I also have problems installing from the fx4ga.exe sent to me via the email links after buying GA5 and the FX addon.
History:
  • DL'd and installed the trial version of GA5.
  • I Decided to purchase and sent for the Boxed Media Version of GA5, and DL'd the fx4ga exe from the email link sent after purchase.
  • When the disc arrived, I uninstalled the trial version and rebooted.
  • I installed GA5 from the disc.
  • I ran the saved fx4ga exe file (which I've re-DL'd 3 times)
Effect:
The normal install dialog comes up at first, but then I click on "Yes", an small & empty dialog pops up with only an "OK" button on it. When I click it, I get an error saying "Extstub has performed an illegal operation and will be shut down", with the following details:
Code: Select all
EXTSTUB caused a general protection fault
in module FX4GA.EXE at 0002:0000a1c9.
Registers:
EAX=00003faf CS=48ef EIP=0000a1c9 EFLGS=00000206
EBX=0000676a SS=45af ESP=00006c50 EBP=00006c54
ECX=00010000 DS=45af ESI=000028da FS=0000
EDX=00000000 ES=0000 EDI=0000295a GS=015f
Bytes at CS:EIP:
ff 1d eb ee c3 55 8b ec b8 fc 00 50 e8 d5 02 b8
Stack dump:
0000a13b a00f6c60 6cc00000 45af0000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 6c8c6c81 6c80000a 00006e94 6cbc6c81
If anyone can help me with this, I'd much appreciate it. I'd like to be able to use the additional FX, especially since it was an extra cost to get it!
bryave
codecs
Post by bryave »
You might have existing codecs that conflicts with the plug-in. As far as I know 3ivx codecs appears to have problem with these plug-ins. Could you try removing them and tell me if it works. Thanks. :D
†bryave
janetgalle
cannot even open the downloaded file
Post by janetgalle »
Hi all,
I too have purchased and downloaded Gif animator 5 and Ulead F/X for GIF Animator. The Animator installed OK, but I can't even open the fx4ga file. I get this error message:
16 bit Windows Subsystem
C:\WINDOWS\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for running MS-DOS and MS Windows applications. Choose close to terminate the application.
I am severly "Techno Challenged" :roll: and have no idea what this means or what to do about it.
Help?
Thanks,
jg
htchien
operating_system: Mac
Post by htchien »
I think you can contact Ulead Tech Support for the problem.
http://www.ulead.com/tech/techsupport.htm
Hope this helps.
H.T.
Ted (H.T.)
bryave
msKB
Post by bryave »
janetgalle,
You can search this autoexec.nt issue with Microsoft KnowledgeBase. I think there's an instruction where you will copy and paste codes into your autoexec.nt file in your system.
Helping further... :D
†bryave
bobthecomputer
Problems with installing Ulead F/X for GIF Animator
Post by bobthecomputer »
I Payed for the test Ulead GIF Animator 5 TBYB after the time was up, and then also purchased the Ulead F/X package for it online.
Now the GIF 5 works fine, but even after uninstalling all files a couple times, I still can't get the Ulead F/X package to install.
Tried calling tech support, but seems no ones ever there and is costing me.
When trying to install the fx4ga.exe file, all I keep getting is:
Sorry! We can not find the Ulead GIF Animator 2.0 or above in your system. Please install the ULead GIF Animator 2.0 or above then run this program again.
Also when I just try to extract the exe file, all that is in it is a: 1kb os.dat file. *shrug*
Anyone have a sollution for me?
Help is needed soon as paid for it and would like to use it.
Thanks,
Bobthecomputer 8)
