Trouble Creating a DVD File--VS8
gmb468
Post by gmb468 »
I have reached the point of creating my output and have successfully created an MPEG1 (~170M) and MPEG2 (650+M) file. I wanted to dump it to a DVD file but VS8 keeps locking up forcing me to reboot. I have plenty of empty disk space (14G) so I don't think it is an issue with that. Any thoughts or suggestions?
Am I wasting my time creating a DVD file? Can I just burn the MPEG1 or MPEG2 file to a DVD and get a quality output?
Thanx,
GMB
erock1
Post by erock1 »
GMB,
I could be wrong but I don't think you can create a single DVD folder or image from an MPEG-1 & MPEG-2 as they are different. MPEG-1 is VCD standard and MPEG-2 is DVD. As for burning both types of files to a disc, you could do it but don't expect it to play in a set top player.
gmb468
Post by gmb468 »
Sorry. I wasn't clear with my first message now that I read it again.
I have created an MPEG1 file and will burn it as a VCD. I have created an MPEG2 and will burn in on a separate disk. I was trying to create a DVD file using the "createvideo" but in the creation process, MP8 locks up. I had planned to burn this "DVD format" file to a DVD.
Based upon your comments, can I assume that MPEG2 is a DVD format and thatI could burn it on a DVD disk and get the same results? Is there a difference between MPEG2 and DVD? If so, what is it?
Thanx,
GMB
erock1
Post by erock1 »
gmb468 wrote:I have created an MPEG1 file and will burn it as a VCD. I have created an MPEG2 and will burn in on a separate disk. I was trying to create a DVD file using the "createvideo" but in the creation process, MP8 locks up. I had planned to burn this "DVD format" file to a DVD.
Thanx,
GMB
GMB, I still believe you can not create a new file using 2 different formats, MPEG-1 & MPEG-2. The only way (and I could be wrong) you can do this is to create the new file by rendering either MPEG-1 or 2 to the other's format first. In other words, place both MPEG-1 & MPEG-2 files in VS timeline and render all to MPEG-1 or MPEG-2.
Basically, MPEG-2 is the standard DVD format. RThey are one and the same. The only thing that can change is the typr of audio contained and the type of bit rate used.
GeorgeW
Post by GeorgeW »
As long as the mpeg-1 and mpeg-2 videos meet DVD compliant specs (they are different for mpeg-1 vs. mpeg-2), they can be included on the same DVD.
Authoring applications that can handle multi-VTS (multiple Video Title Sets) will handle them properly. At some point, Ulead upgraded MovieFactory and the authoring tool in VideoStudio to handle multi-VTS's. So, VideoStudio 9 could work with properly encoded mpeg-1 and mpeg-2 videos in the same DVD project without needing to re-encode them :)
George
