Unspecified error during burn
daddog
Post by daddog »
At a loss here. Have burned several projects with X4 and this is the first time I have come across the unspecified error during the burning process.
Empty time line
Create Disk
DVD
Add VS Project
Project Settings
Do not convert (check)
Treat MPEG audio as non-DVD compliant (check)
Auto repeat when disk playback ends (check)
Upper field First
No motion menu
No music track
Recording Format: DVD Video
Create to disk (check)
Normalize audio (have done it checked and unchecked and still have the error.
I have looked over the forums. One fellow said uninstalling X3 solved his problem. I did the same, but no joy.
Anyone have any ideas?
aka James or dd :)
MB Gigabyte GA-EP45T-UD3P
CPU Intel 2 Duo E8500 3.16GHz
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
LiteOn DVD Burner SOHW-1693S
Sony HDR-CX550V camcorder
http://www.332nd.org/
Re: Unspecified error during burn
Post by Black Lab »
It has been reported that you MUST have motion menu and background music checked or else you get the message you reported. Try it and see what happens.
daddog
Post by daddog »
Thanks! Will try right now. :)
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
daddog
Post by daddog »
You rock sir. :)
That was it. :)
aka James or dd :)
Windows 7 64bit
GeoForce GTX 260
4GB of RAM
DirectX 10
Post by Black Lab »
8)
Kingston
motherboard: Gateway [Acer] DX4860
processor: Intel Core i5 3rd gen. 3 GHz
ram: 8 GB
Video Card: Intel HD 2500
sound_card: Bluetooth
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Post by Kingston »
Try changing the Motion Out effect to None. That seems to clear up the problem when there's no motion menu and the audio is deleted or too short.
Luna Esterhuizen
motherboard: DELL XPS 15 9520
processor: Intel Core i7 12700H
ram: 32 GB DDR5
Video Card: GEFORCE RTX 3050 4GB DDR6
Hard_Drive_Capacity: 8TB
Monitor/Display Make & Model: Dell 1920 X 1200
Corel programs: Video Studio Ver 9 to VS 2021 Ultimate
Post by Luna Esterhuizen »
I do not like motion menus of background music and had the same error when I checked it off. So I also changed the Motion Out to none and it worked.
However I like the Motion Out options why doesn't it work as in previous versions. I came to look for a patch but there is no patch available. It was quite a struggle to get my first iso done with all the unspecified errors. Hope someone can help. Regards
L E
Luna Esterhuizen
ram: 32 GB DDR5
Hi Jeff,
I use X4 and never experienced the same error with X2. As far as I know motion menu plays a looping motion clip of the first few images when choosing Thumbnail menus which is too busy for my taste. I usually use text menus.
I made several tests now and it came to one thing: If you don't want motion menus and leave it unchecked then you have to set you menu out to none. Even if you choose a text menu and you uncheck motion menu.
To me this is definitly an error in X4 because I always used the setting for no motion, but a fade out menu with X2.
I'll be looking for a patch to correct this error soon.
Regards
L E
drchris
motherboard: Gigabyte GA-B75M-D3h
processor: Intel Core i5-3450
ram: 8 GB
Hard_Drive_Capacity: 1000 GB
Post by drchris »
I know this is an old post, but I have been wrestling with this problem for a couple of weeks and I wanted to share my experience with others having the same problem. I am using VideoStudio Pro X4 and kept getting the unspecified error 5.0.0 at the end of the burning process. I am running Windows 7 Home Premium 64 bit. I tried many of the suggestions that I found online including multiple combinations of settings within VideoStudio, but they didn't seem to make a difference. In the meantime I have used a lot of blank discs (including bluray).
Here is what I did to solve the problem for me:
Created restore point, deleted VideoStudio
Deleted two video conversion software programs and a couple of other unrecognized programs I had
Scanned for viruses and malware (none found)
Updated QuickTime to latest version
Updated the firmware for my DVD-Bluray burner (LG-BH14NS40)
Restarted computer
Re-installed Pro X4 into default directory (I had it in another location before)
Installed service pack 3 for X4 and now it works fine
I'm not sure which of these actually fixed the problem since I did them all at once. :D
