I create a project in Video Studio 9 and save it as a .VSP file. I then try to import that file into Movie Factory 4 to create a DVD and MF 4 states this file is not supported. The Movie Factor 4 User Manual clearly states.."You can also
add a VideoStudio project (.VSP)."
This should clearly work since I can create a project in VS 9 and then click "create disc" which opens up a lite version of MV 4 within Video Studio and runs the .VSP file. Since the Disc creator in VS 9 is just a lite version of the MV 4 Disc creator this should be fully compatible.
Anyone else have this problem or know how to get around it? I do not want to have to render a project in VS 9 and then import it as an .mpg into MV 4 and then render it again to make the DVD. I also need the additional layout and editing capability of the MV4, otherwise I would create the disc in VS 9's disc creator.
thanks beullar
Importing a Video Studio .VSP file to MV 4
beullar
Thanks...but problem still exists
George.....Thanks for the advice but the time to create an .mpg file and import it into the MV 4 is way too long. I need to import as many as 6 .VSP files into MV 4 which will create the titles. Saving the files as only a .VSP in Video Studio allows me to bypass the step of rendering and working much quicker. It also allows me to return to VS 9 and edit the file to make any changes then go back to MV 4.
The point is that MV 4 clearly states that importing .VSP files is an option. I also use Roxio's Media Creator 7.5 and working between Video Wave 7 and Roxios Disc Creator is flawless and transparent. In fact, I can open Video Wave from within Disc Creator to edit my project....something I wish Ulead could do. The integration between VS 9 and MV 4 should be MUCH tighter and transparent.
maddrummer3301
