I have noticed that there is only 1 transition in both the ALBUM and FLASHBACK 'folders' in VS Pro X3 yet in VS 9 (and VS 10 I think) there are around 15 in each (folder).
The relevant file names (containing the transitions in each 'folder') are in the Vfx_Plug directory (folder) but are they interchangeable (can I just copy them across from VS9 to VS X3 without causing problems)?
Are transitions interchangeable?
- jparnold
- motherboard: Gigabyte Z390 UD
- processor: Intel Pentium i7 9700 3dot6Ghz
- ram: 16GB DDR3
- Video Card: Gigabyte RTX2060 OC 6GB
- sound_card: Onboard Realtec ALC887
- Hard_Drive_Capacity: 2048Gb mix
- Monitor/Display Make & Model: Samsung S27C450B
- Corel programs: Videostudio X10, Paint Shop Pro 2018
John a
Re: Are transitions interchangeable?
You can try, but I don't think you really need to.
They have streamlined them, well maybe not the album transitions. They reduced them due to the problems people were having using them. However for the others, click the customize button, and you'll find that you still can achieve all those that were presented in earlier versions as thumbnails in the library.
see if my post in this topic :-
http://forum.corel.com/EN/viewtopic.php?f=1&t=41444
helps you at all John.
