My video segments are Dobly Digital 5.1 yet when I burn a disk using Movie Factory SE it only supports DD 2. X2 worked fine with DD 5.1. Is there a work around?
Thanks, Pat
DVD Movie Factory SE - No Dobly Digital 5.1
PatBarr
- motherboard: A8M2N-LA
- processor: AMD Athlon 64 3500+
- ram: 2GB
- Video Card: ATI FireMV 2200
- sound_card: motherboard
- Hard_Drive_Capacity: 150GB
- Monitor/Display Make & Model: WDI L1975NW
Thanks, Pat
Re: DVD Movie Factory SE - No Dobly Digital 5.1
I know this was discussed a few months ago, but my recollection is a bit hazy. But if I recall correctly, if you put a fully DVD-compliant mpeg-2 file into MF 7 SE with 5.1 audio, and make sure the 'do not convert compliant mpeg files' box in the Options icon in the bottom left of screen is ticked, it is processed and output as 5.1...
PatBarr
- ram: 2GB
I tried this and it still was generated as DD 2.
Thanks, Pat
When you finally hit the burn button, if the process starts with Convert Title then your video is being converted. What do you see after hitting the Burn button?
Kingston
- motherboard: Gateway [Acer] DX4860
- processor: Intel Core i5 3rd gen. 3 GHz
- ram: 8 GB
- Video Card: Intel HD 2500
- sound_card: Bluetooth
- Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
I tried it and got DD5.1.
No conversion was required.
When I added the shared MPEG-2 file to DVDMF SE, DVDMF SE asked if I wanted the project settings changed so smart rendering could be performed. I said okay to that. I burned the DVD to a folder, then used MediaInfo to check the audio properties of one of the VOB files. The audio was DD 5.1.
