I have VSP X3 with the latest updates/patches. I created a project using .mod files that were taken with a JVC video camera. I used VSP to do a batch convert of the files and turn them into .mpg files. My project came out wonderfully, and I have successfully burned a DVD of my project. However, I wanted to create an mpg file of the project, just so I could watch it on my laptop or iPod if I wanted to. I click on SHARE and then Create Video File. I select my location, choose .mpg from the drop down list and start rendering. The progress bar moves along fine, I can see my file being created, however when the rendering gets to 99% the progress bar closes and the file that was being created disappears, no error messages or anything. I have another project that I was able to render in mpg format without any problems, so I don't believe it's an application issue.
When I right click on a movie clip in the timeline (of the project that will not render) and select properties, it tells me the type is MPEG-2 Lower Frame First. When I right click on a movie clip in the timeline (of the project that does render) and select properties, it tells me the type is MPEG-1. Now I used VSP batch convert to convert the files of both projects from .mod to .mpg. I'm not sure why these files came out as MPEG-2 vs. MPEG-1 when I selected .mpg for both batch convert operations.
I tried to batch convert the .mod files again to a different format and then relink them into my project, but I get an error saying that the duration of the newly converted file needs to be a certain amount of time. But I don't understand why as it is the same length as the file I am trying to replace in my project.
Is there a setting I'm missing to get the Create Video to work with these MPEG-2 files?
System
Windows 7 Home Premium
2nd Gen Intel Core i7
8GB RAM
750GB H/D
Thank you in advance for your responses.
SHARE - Create Video failing
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Re: SHARE - Create Video failing
Hello rebg7474,
There are many reasons why this happens and downloading/installing the latest codecs is a start.
Here are some of the codecs that you may want to install.
RealPlayer: http://www.real.com/
DivX: http://www.divx.com/en/software/divx-plus/codec-pack
XviD: http://downloads.xvid.org/downloads/xvidcore-1.3.1.zip
Windows Media Player: http://windows.microsoft.com/en-US/wind ... dia-player or just download the Windows Encoder at http://www.microsoft.com/expression/pro ... rview.aspx
QuickTime: http://www.apple.com/quicktime/download/
Direct X: http://on-msn.com/aLrk0j (WinXP)
Direct X: http://www.microsoft.com/Windows/window ... tx-11.aspx
Just reply back for any update.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
